I have an issue with the Instrument Cluster on my 2010 Passat R36. As you can see from the photo the tachometer needle is not illuminated. This is an intermittent problem - usually at the start of the day it is blue and then during the day the light will go off, only to return the next day. Kamold thought it might be faulty surface mounted leds, but I took it to an instrument specialist who couldn't find a problem - the led light for the tacho needle worked when he tested it. He thought it might be a power supply issue. Is it possibly a loose pin in the instrument cluster plug? Or something else? Any suggestions?
Passat R36 Instrument Cluster
You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoBiscay Blue MY10.5 Passat R36 Wagon
Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
Atlantic Blue MY19.5 Golf GTI
Options: Luxury Package and Sound & Style Package.Tags: None
Do you think the solution is to change the offending LED lights? The instrument specialist who looked at my cluster isn't prepared to help me - he thinks it is a module issue. Everything else in the instrument cluster - lights, dials, etc - works perfectly.
What should I do?Biscay Blue MY10.5 Passat R36 Wagon
Only three components run those, a resistor, a transistor and the led itself, with the other side working it means the MCU is working to turn it on.
I have a spare R36 cluster, if you want to do a swap out repair. I can match your ODO and do an exchange if you like? DM me if your interested.MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Thanks MIG. Is it possible for the cluster to be repaired? Or is it not economically viable to do so?Originally posted by MIG View PostOnly three components run those, a resistor, a transistor and the led itself, with the other side working it means the MCU is working to turn it on.
I have a spare R36 cluster, if you want to do a swap out repair. I can match your ODO and do an exchange if you like? DM me if your interested.Biscay Blue MY10.5 Passat R36 Wagon
Yes the cluster should be able to be repaired, there are not many things that issue could be caused by overall, if you like maze puzzles trace out the LED circuit here
. worse case the PCB can be swapped with a B7 cluster as the R36 dials are the rare part.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoMY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
That PCB looks a bit different to mine! I'll send you a PM.Originally posted by MIG View PostYes the cluster should be able to be repaired, there are not many things that issue could be caused by overall, if you like maze puzzles trace out the LED circuit here
. worse case the PCB can be swapped with a B7 cluster as the R36 dials are the rare part.Biscay Blue MY10.5 Passat R36 Wagon
