2010 r36 cannot read engine module with VCDS
    Yeah I don't have one but I'll have to try and get access to one. Would make it a bit easier to isolate.
      ill put this on my list of things to re-invent and sell to the masses....$100 smoke machine.
      VW rides: 04 R5 touareg (wifes), 05 R5 touareg (sold), 05 Passat sedan v6 (sold), 2010 r36 wagon, 68 beetle (sold)
      other rides: 00 Kawasaki ZX9R Ninja, Renault sport 225
        Then you could blow smoke up....into engine bays to find leaks...
          After making myself a bit sick and with head spins after trying the cigar smoke blowing method to find the leak, I took the intake back off and had a good look at everything. Pulled off and inspected the vacuum pump, cleaned all mating surfaces and put everything back together.
          Found that the single M10 bolt at the back of the intake was cross threaded so it was causing the whole alignment to slightly skewed. Cleaned up the thread and hole and now no more leak! Thankfully was something simple/stupid.
            great success! i did consider getting a vaping friend over to try blow some clouds
            ill pull the intake for a detailed look if this other MAF doesnt do anything.
            i am wondering if by me just deciding to clean the MAF i actually created a problem......looking at the cross sectional design of the gen 6 MAF there is potential to wash crud deep into it and there isnt a clear shot to get it out, the actual sensor unit is pretty well bonded to the housing too, i have it a bit of a tweak and it didnt budge.
            there is good info in the vr6 self study guide: http://sandbox.enjoybeing.net/veedub...self_study.pdf
              Bit of an update.
              Received my OBDeleven.
              Getting 2 engine faults recurring.
              P119A fuel pressure sensor malfunction.
              "upper limit exceeded"
              P1647 check coding/versions of control modules in drive train
              "implausible signal"
              I clear this and the engine stops rev hunting
              The second code is pretty much constant, the first comes and goes a bit
              Thoughts?
              Fuel rail pressure 40 bar at idle
              Fuel pump at idle 4.8 bar
              Fuel rail pressure 4000rpm in park 67bar
                First fault is probably the sensor itself. I'd first try just unplugging it, check/clean contacts and reseat. If the fault returns replace the sensor:
                P119A/004506 - Ross-Tech Wiki
                Second fault indicates there is another control module on powertrain canbus that is not correctly coded.
                Do you have a fault in your ABS module?
                  ill have a play with the sensor.
                  im pulling the clockspring assebly out for a look today.
                  here is the rest of the log
                  Fault
                  Control unit: 01 Engine
                  Active faults: 0
                  Inactive faults: 1
                  System description: CC3.6-FSI-EU5 G
                  Software number: 03H906032FS
                  Software version: 4855
                  Hardware number: 03H906032AB
                  Serial number: VWZCZ000000000
                  Faults:
                  P1647 - Checking coding/versions of control modules in drivetrain Implausible signal
                  Active
                  Mileage: 210310 km
                  Date: 2019-09-13 07:29
                  Fault
                  Control unit: 02 Transmission
                  Active faults: 0
                  Inactive faults: 1
                  System description: GSG DSG AG6 511
                  Software number: 02E300012L
                  Software version: 2103
                  Hardware number: 02E927770AL
                  Hardware version: F11
                  Serial number: 00001005240165
                  Faults:
                  U0235 - Lost Communication With Cruise Control Front Distance Range Sensor
                  Active
                  Mileage: 210310 km
                  Fault
                  Control unit: 03 Brakes
                  Active faults: 0
                  Inactive faults: 1
                  System description: J104 C4 440 V2
                  Software number: 3C0614109AF
                  Software version: 0015
                  Hardware number: 3C0614109AF
                  Hardware version: K03
                  Serial number: 00000705892119
                  Faults:
                  00778 - Steering angle sensor no or incorrect basic setting/adaptation
                  Active
                  Mileage: 210310 km
                  Fault
                  Control unit: 08 Air Conditioning
                  Active faults: 0
                  Inactive faults: 0
                  System description: Climatronic
                  Software number: 5K0907044BT
                  Software version: 0709
                  Hardware number: 5K0907044BT
                  Hardware version: H15
                  ODX name: EV_Climatronic
                  ODX version: A01006
                  Faults:
                  No trouble codes found
                  Mileage: 210310 km
                  Date: 2019-09-13 07:30
                  Fault
                  Control unit: 09 Central Electrics
                  Active faults: 0
                  Inactive faults: 0
                  System description: Bordnetz-SG H54
                  Software number: 3C8937049E
                  Software version: 2602
                  Hardware number: 3C8937049E
                  Hardware version: 063
                  Serial number: 00000003986828
                  Faults:
                  Mileage: 210310 km
                  Fault
                  Control unit: 10 Parking Assistance 2
                  Active faults: 0
                  Inactive faults: 0
                  System description: PARKHILFE 8K
                  Software number: 3C8919475A
                  Software version: 0009
                  Hardware number: 3C8919475
                  Hardware version: H07
                  Serial number: 08791015951159
                  Faults:
                  Mileage: 210310 km
                  Fault
                  Control unit: 15 Airbag
                  Active faults: 0
                  Inactive faults: 0
                  System description: J234__003 VW10 HI
                  Software number: 5N0959655M
                  Software version: 1916
                  Hardware number: 5N0959655M *
                  Hardware version: 003
                  Serial number: 003GGPBZ36YK
                  Faults:
                  Mileage: 210310 km
                  Fault
                  Control unit: 16 Steering Column Electronics
                  Active faults: 0
                  Inactive faults: 4
                  System description: LENKS.MODUL
                  Software number: 5K0953569AS
                  Software version: 0180
                  Hardware number: 5K0953569AS
                  Hardware version: 016
                  Serial number: 20170503200509
                  ODX name: EV_VW360SteerWheelUDS
                  ODX version: A03004
                  Faults:
                  B114411 - Turn signal switch Short circuit to ground
                  Active
                  B114913 - Windshield wiper intermittent mode switch Open circuit
                  Active
                  U108E00 - Control unit in steering wheel No Communication
                  Active
                  B116854 - Steering angle sensor No basic setting
                  Active
                  Mileage: 210310 km
                  Fault
                  Control unit: 17 Dash Board
                  Active faults: 0
                  Inactive faults: 0
                  System description: KOMBI
                  Software number: 3C0920872J
                  Software version: 0305
                  Hardware number: 3C0920872J
                  Hardware version: H03
                  Serial number: 00000000000000
                  ODX name: EV_Kombi_UDS_VDD_RM09
                  ODX version: A04052
                  Faults:
                  Mileage: 210310 km
                  Date: 2019-09-13 07:31
                  Fault
                  Control unit: 19 Gateway
                  Active faults: 0
                  Inactive faults: 0
                  System description: J533 Gateway H13
                  Software number: 3C0907530Q
                  Software version: 0172
                  Hardware number: 3C0907951
                  Serial number: 3620P1062404E7
                  Faults:
                  Mileage: 210310 km
                  Fault
                  Control unit: 22 All Wheel Control
                  Active faults: 0
                  Inactive faults: 0
                  System description: Haldex 4Motion
                  Software number: 0BS907554B
                  Software version: 4015
                  Hardware number: 0BS907554B
                  Faults:
                  Mileage: 210310 km
                  Fault
                  Control unit: 25 Immobilizer
                  Active faults: 0
                  Inactive faults: 0
                  System description: IMMO 052
                  Software number: 3C0959433AM
                  Software version: 0383
                  Hardware number: 3C0959433AM
                  Hardware version: 008
                  Faults:
                  Mileage: 210310 km
                  Fault
                  Control unit: 2E Media Player Position 3
                  Active faults: 0
                  Inactive faults: 0
                  System description: SG EXT.PLAYER
                  Software number: 5N0035342C
                  Software version: 0111
                  Hardware number: 5N0035342C
                  Hardware version: H13
                  Serial number: 7668204731
                  Faults:
                  Mileage: 210310 km
                  Fault
                  Control unit: 36 Seat Adjustment Driver Side
                  Active faults: 0
                  Inactive faults: 0
                  System description: Sitzverstellung
                  Software number: 3C0959760E
                  Software version: 1101
                  Hardware number: 3C0959760E
                  Hardware version: 000
                  Faults:
                  Mileage: 210310 km
                  Fault
                  Control unit: 42 Door Electronics Driver Side
                  Active faults: 0
                  Inactive faults: 0
                  System description: TUER-SG FT
                  Software number: 3C0959701A
                  Software version: 0306
                  Hardware number: 3C0959793A
                  Hardware version: 002
                  Serial number: 0000885207
                  ODX name: EV_DCU42BroseDriveSide
                  ODX version: A03004
                  Faults:
                  Mileage: 210310 km
                  Fault
                  Control unit: 44 Steering Assistance
                  Active faults: 0
                  Inactive faults: 0
                  System description: EPS_ZFLS Kl. 143
                  Software number: 1K0909144J
                  Software version: 3001
                  Faults:
                  Mileage: 210310 km
                    Fault
                    Control unit: 46 Central Module Comfort System
                    Active faults: 0
                    Inactive faults: 1
                    System description: KSG PQ46 RDK 052
                    Software version: 0412
                    Faults:
                    01134 - Alarm horn
                    Active
                    Mileage: 210310 km
                    Date: 2019-09-13 07:32
                    Fault
                    Control unit: 47 Sound System
                    Active faults: 0
                    Inactive faults: 0
                    Software number: 5K0035456
                    Software version: 0340
                    Hardware number: 5K0035456
                    Hardware version: H06
                    Faults:
                    Mileage: 210310 km
                    Fault
                    Control unit: 52 Door Electronics Passenger Side
                    Active faults: 0
                    Inactive faults: 0
                    System description: TUER-SG BT
                    Software number: 3C0959702A
                    Hardware number: 3C0959792A
                    Serial number: 0000863534
                    ODX name: EV_DCU52BrosePasseSide
                    ODX version: A03004
                    Faults:
                    Mileage: 210310 km
                    Fault
                    Control unit: 53 Parking Brake
                    Active faults: 0
                    Inactive faults: 0
                    System description: J540 EPB3 VW-15417
                    Software number: 3C8907801E
                    Software version: 0007
                    Hardware number: 3C8907801E
                    Serial number: 00000000330261
                    Faults:
                    Mileage: 210310 km
                    Fault
                    Control unit: 55 Headlight Regulation
                    Active faults: 0
                    Inactive faults: 0
                    System description: AFS-Steuergeraet
                    Software number: 5M0907357C
                    Software version: 0142
                    Hardware number: 5M0907357C
                    Faults:
                    Mileage: 210310 km
                    Fault
                    Control unit: 56 Radio
                    Active faults: 0
                    Inactive faults: 0
                    System description: Radio RCD510
                    Software number: 5K0035190
                    Software version: 0167
                    Hardware number: 5K0035190
                    Hardware version: 040
                    Serial number: VWZ1Z3K3534089
                    Faults:
                    Mileage: 210310 km
                    Date: 2019-09-13 07:33
                    Fault
                    Control unit: 65 Tire Pressure Monitoring
                    Active faults: 0
                    Inactive faults: 0
                    System description: RDK
                    Software version: 0453
                    Faults:
                    Mileage: 210310 km
                    Fault
                    Control unit: 69 Trailer Function
                    Active faults: 0
                    Inactive faults: 0
                    System description: Anhaenger
                    Software number: 1K0907383F
                    Software version: 0100
                    Hardware number: 1K0907383F
                    Serial number: 00000131391164
                    Faults:
                    Mileage: 210310 km
                      Ok yep that other ecu fault is because you need to run steering angle sensor calibration.
                        so ive got the clock spring assembly apart and everything looks ok, no visible damage except when im pinning out the ribbon there is 2 pins apart from the rest ive assumed are CAN but they are bridged.
                        generally that's not a good thing, the ribbon checks out, no breakages in itself.the only bit is the moulded plug where i cannot see whats happening.
                        yeah, dunno.
                        • #27
                          replacement bits en route
                          • #28
                            Update, replacement bits fitted and working, had an intermittent fuel pressure fault but it boiled down to poorly seated inlet manifold gasket, such a minor leak still caused faults.
                            Pays to double check, could have saved myself some time. Was bloody sure I got it right the first time but you get that.
                            • #29
                              It's amazing how small a leak can be and still cause an issue
                              • #30
                                Yeah for sure.... Quite a relief to get through all the issues!
