Had the 107k/7yrs major service where they change the timing belt, some other bits and also the water pump. Its a late 2008 Octavia RS so the TFSI 2L engine. It;s my wifes car so I drove it too and from the servicing, but haven't been in it since. I noticed when taking it out tonight that it took longer than usual to warm up, and once it did, it hit the usual 90C mark (dead vertical) where it normally stays. However it actually dropped a bit, and then crept back and did this for about 10k. It was about 20C outside at night and doing 60 and 80k/hr on pretty quiet roads. At one point I took off and it dropped down to the next marker and then crept back up. I parked for about 2hrs and it warmed up pretty quickly but noticed it would drift to the left a bit and then come back. It never got hotter than it should.
When I got home I popped the bonnet and didn't notice anything untoward, although the overflow container was filled well above the min/max line, well up to where it says G12 on it!
I also noticed that the airintake wasn't connected properly at all to the engine cover, guessing that isn't a big deal as the clamp clearly wasn't pushed back so it slipped, I'm guessing the air filter is further on under the engine cover. Never really looked at that before, but was surprised when you looked through the front intake you can see through to the firewall! I'm wondering if they were that sloppy with something obvious, what they might have missed or caused to make this moving temp. From what I remember the needle kind of artificially sits bang on vertical/90C but have never seen it cool down over time!
