What information will using a VAGCOM cable show?
  • What information will using a VAGCOM cable show?
    Hi All
    A bit of a noob question which I've been unable to find a definitive answer to.
    Would using a VAGCOM cable allow me to get a read out of all the historical faults generated on my car? Specifically when oil warnings occurred, blinker faults etc... Or is only current faults?
    Thanks in advance
    It will read current and historic codes up until the previous time the fault codes were erased.
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
      And shows the mileage when faults occurred.
      Looks like this:
      Code:
      Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
         Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
         Component: BCM PQ35  B   103 0537
         Revision: 00103 AC
         Coding: 40180A3AE03518C0C4080080310000E441710088537D8D60648000200000
         Shop #: WSC 01357 011 00200
         VCID: 2D7FD864CD81
         Part No: 1K2 955 119 E
         Component: Wischer 27050  21  0501
         Coding: 009795
         Part No: 1K0 955 559 AH
         Component: RLS 090609 05  54  0402
         Coding: 0730AD
      2 Faults Found:
      01520 - Rain and Light Recognition Sensor (G397)
                  004 - No Signal/Communication - Intermittent
                   Freeze Frame:
                          Fault Status: 00100100
                          Fault Priority: 2
                          Fault Frequency: 8
                          Reset counter: 172
                          Mileage: 21342 km
                          Time Indication: 0
                   Freeze Frame:
                              Term 15 Off
                          Voltage: 12.75 V
                              OFF
                              ON
                              Term 50 Off
                              OFF
                              OFF
                  008 - Implausible Signal - Intermittent
                   Freeze Frame:
                          Fault Status: 00101000
                          Fault Priority: 2
                          Fault Frequency: 4
                          Reset counter: 175
                          Mileage: 24586 km
                          Time Indication: 0
                          Date: 2016.14.21
                          Time: 16:18:18
                   Freeze Frame:
                              Term 15 On
                          Voltage: 14.10 V
                              ON
                              ON
                              Term 50 Off
                              OFF
                              OFF
      Audi A3
        Thanks for the information. It looks like this should give me what I need.
        Next question, would anyone with this cable be available in Sydney to assist? I posted a request on another thread, VAG-COM Scanning but havent received any offers. Financial compensation for your time is open for discussion.
        Thanks again..
          Ask in here:
          VCDS Technical Resources
          Audi A3
            Just remember the key point:
            Meaning if the fault has not reoccured it will not show up if it was cleared. To be clear you don't get a history of every fault ever, just the "current" ones.
              Faults can disappear by themselves as well depending on the fault severity, if they don't happen again for a number of trips. This is the reset counter.
              Audi A3
                I have VCDS Cable.
                Where are you located?
                \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
                ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
