Cheers Tigger. Although the car was purchased new, it's quiet a few years old now. The cost to go stage 2 (tune, controller, dp, IC, trans tune) seems to be getting more and more when the cars realistic value is $15k maybe?
5N Tiguan with IE Tune
Now at 63k kms, the Tiguan is such fun to drive.
Stage 2 IE tune is perfect.
Have done a few mods now, such as TCU tune, larger S3 intercooler, Eibach springs, rear sway bar, front engine strut brace, DBA slotted rotors & extreme pads, etc. 230awhp
I'll finish it off with shocks, cat-back system, and a nice little K04 turbo with the IE stage3 tune. Pretty happy with the Laborde Motorsports stage2 TCU tune for the DQ500. A big upgrade over stock....
72,000kms, all going well.
Just installed a K04 HPA hybrid turbo 2 days ago with the help of a mobile mechanic. Was a hot 39deg day, but got it done. Fits perfectly, however Ive now lost boost reading to my boost gauge. Line comes off the intake manifold. I haven't looked into it yet, just test driving and enjoying the IE Stage 3 K04 tune I flashed on afterwards (eventually, lost signal after the erase procedure so had a fright there that's for sure). The Tiguan is manic now, pulls hard through the gears with wheelspin in 3rd gear. Awaiting an upgraded CTS engine mount to hopefully help a bit.
I'm expecting the 2.0tsi EA888 gen.2 engine should now be north of 330hp, I'll get it onto the dyno soon-ish but first need to do some datalog runs in 3rd on a straight out-of-the-way country road. So far so good, the IE K04 tune feels good
Tiguan 5N 132tsi, DQ500 7spd DSG, AWD, towbar, 72000kms
Fresh fluids & filters throughout (coolant, fuel, cabin, A/C, brakes, engine, AWD, DSG)
HPA K04 hybrid turbocharger upgrade
Stage 3 ECU tune with Integrated Engineering (IE K04 tune)
Stage 2 TCU tune by Laborde Motorsport
Passat CC paddle shift steering wheel
Newsouth Performance boost gauge
Audi RS redtop coilpacks with BKR7EIX .027” sparkplugs
Audi S3 front mount intercooler
Spulen chargepipe intercooler hardpipe kit
K&N pod air filter, custom air intake setup
GFP DV+ diverter valve
HPA 3” turbo downpipe with hi-flow cat, into Racecraft 3” resonator
X-force 2.5” round mid-muffler, Racecraft 2.5” oval end-muffler
ECS Front stainless steel brake lines
Front 312mm slotted rotors & Bendix ultimate pads
Speedbleeders front & rear, 600c fluid
USP Rear stainless steel brake lines
Rear 282mm DBA T3 4000 slotter rotors @ RDA extreme pads
Eibach lowered springs
Hardrace front strut brace
Superpro rear adjustable swaybar links
Superpro 24mm rear swaybar
Superpro torque arm bush kit
Metal torque arm brace
Superpro front lower arm block bush kit
Bartek HPFP upgrade with new roller collar bearing
Ross-Tech VCDS / IE Flash Wizard
To Be Installed
ECS intake manifold spacer
ECS Engine mount upgrade
Deatschwerks DW300 fuel pump
