5N Tiguan with IE Tune
  • #16
    Cheers Tigger. Although the car was purchased new, it's quiet a few years old now. The cost to go stage 2 (tune, controller, dp, IC, trans tune) seems to be getting more and more when the cars realistic value is $15k maybe?
    • #17
      Now at 63k kms, the Tiguan is such fun to drive.
      Stage 2 IE tune is perfect.
      Have done a few mods now, such as TCU tune, larger S3 intercooler, Eibach springs, rear sway bar, front engine strut brace, DBA slotted rotors & extreme pads, etc. 230awhp
      I'll finish it off with shocks, cat-back system, and a nice little K04 turbo with the IE stage3 tune. Pretty happy with the Laborde Motorsports stage2 TCU tune for the DQ500. A big upgrade over stock....
      • #18
        72,000kms, all going well.
        Just installed a K04 HPA hybrid turbo 2 days ago with the help of a mobile mechanic. Was a hot 39deg day, but got it done. Fits perfectly, however Ive now lost boost reading to my boost gauge. Line comes off the intake manifold. I haven't looked into it yet, just test driving and enjoying the IE Stage 3 K04 tune I flashed on afterwards (eventually, lost signal after the erase procedure so had a fright there that's for sure). The Tiguan is manic now, pulls hard through the gears with wheelspin in 3rd gear. Awaiting an upgraded CTS engine mount to hopefully help a bit.
        I'm expecting the 2.0tsi EA888 gen.2 engine should now be north of 330hp, I'll get it onto the dyno soon-ish but first need to do some datalog runs in 3rd on a straight out-of-the-way country road. So far so good, the IE K04 tune feels good
        Tiguan 5N 132tsi, DQ500 7spd DSG, AWD, towbar, 72000kms
        Fresh fluids & filters throughout (coolant, fuel, cabin, A/C, brakes, engine, AWD, DSG)
        HPA K04 hybrid turbocharger upgrade
        Stage 3 ECU tune with Integrated Engineering (IE K04 tune)
        Stage 2 TCU tune by Laborde Motorsport
        Passat CC paddle shift steering wheel
        Newsouth Performance boost gauge
        Audi RS redtop coilpacks with BKR7EIX .027” sparkplugs
        Audi S3 front mount intercooler
        Spulen chargepipe intercooler hardpipe kit
        K&N pod air filter, custom air intake setup
        GFP DV+ diverter valve
        HPA 3” turbo downpipe with hi-flow cat, into Racecraft 3” resonator
        X-force 2.5” round mid-muffler, Racecraft 2.5” oval end-muffler
        ECS Front stainless steel brake lines
        Front 312mm slotted rotors & Bendix ultimate pads
        Speedbleeders front & rear, 600c fluid
        USP Rear stainless steel brake lines
        Rear 282mm DBA T3 4000 slotter rotors @ RDA extreme pads
        Eibach lowered springs
        Hardrace front strut brace
        Superpro rear adjustable swaybar links
        Superpro 24mm rear swaybar
        Superpro torque arm bush kit
        Metal torque arm brace
        Superpro front lower arm block bush kit
        Bartek HPFP upgrade with new roller collar bearing
        Ross-Tech VCDS / IE Flash Wizard
        To Be Installed
        ECS intake manifold spacer
        ECS Engine mount upgrade
        Deatschwerks DW300 fuel pump
