16x8 with a et20 will be perfect.
Josh's MK2 Golf GTI
So anyway, I still have this car for one reason or another.
Sometimes the car won't start, the engine will just turn over freely really quickly as if there's no resistance. If you then turn the key all the way to off, then back to on and let the fuel pump prime, it will start perfectly.
I changed out the battery as the old one was showing black on the water indicator (it's a sealed battery) and was far below the recommended cca for this car, so I changed it out for a new one that meets the spec, it turns over more strongly/faster but still sometimes won't start.
Car will normally start first go, drive to destination, do whatever, come back and it won't start anymore so I thought maybe the coolant temperature sensor? But it does also sometimes do it cold, air flow sensor?
I tested the wiring going to the fuel pump and it's getting about 10v, is that up to spec or should it be closer to 12v?
I can hear the fuel pump prime if I get someone to turn the key for me.
Sorry for the fragmented way I've posted this. I might go try cleaning the air flow sensor.
My MK1 used to have this problem and I traced it back to an intermittent connection to the fuel pump. I wired in a new line to the pump with a hidden on/off switch under the drivers seat.
If you do this make sure it is taken off a power source that only comes on when the ignition is turned on.
Paul1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
Well the throttle/acceleration does cut out pretty much every 3-4 seconds for a brief moment (less than a second) especially noticeable when you're burying your foot in to it...
Does seem like it would be the fuel pump and/or the connection to it. I don't know how to test it other than throwing in a new fuel pump? The area under the black pump cover is full of grime as if its never been touched since factory.
Sounds like fuel starvation.
When was the last time the fuel filter was changed?1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
That's an excellent question. Never been changed since I've owned it (have done less than 5,000km in the 13 months I've had it.) and no idea if the previous owner/s ever changed it. I assume there's the main fuel filter (where?) and a pre filter screen on the fuel pump?Originally posted by sports racer View PostSounds like fuel starvation.
I feel like I should bring attention to what I said previously about the voltage to the fuel pump too "I tested the wiring going to the fuel pump and it's getting about 10v, is that up to spec or should it be closer to 12v?"
It's actually slightly under 10v on the plug.
I'm not sure if 10v is right. It could be caused by too much load on the pump.
Disconnect the +ve wire to the pump and see what the voltage is just on the wire without any load. Bet you it's 12v and the pump is straining to deliver fuel because the filter is clogged.
This is where not having my MK2 in front of me makes things a bit harder otherwise I'd just measure the voltage on mine. Pumps are mechanically operated and would be slower on reduced voltage. Can you run a new wire from the battery direct to the pump and listen to the pump to see if it sounds better.
Have you replaced the fuel filter yet?1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
No not yet, I'm juggling problems with 3 cars at the momentOriginally posted by sports racer View PostThis is where not having my MK2 in front of me makes things a bit harder otherwise I'd just measure the voltage on mine. Pumps are mechanically operated and would be slower on reduced voltage. Can you run a new wire from the battery direct to the pump and listen to the pump to see if it sounds better.
(all mine too...)
