nice work chris, great to see it coming together, better pull my finger out now hey and catch up
Mk1 16v Project
 Ha, yes you should extract that digit! Your donk will be a lot more impressive than this one...Originally posted by Volksee77 View Postnice work chris, great to see it coming together, better pull my finger out now hey and catch up
 Don't get too carried away.. Once I get the car back the engine and box have to come back out so the bay can be painted.. But it's a start!!Originally posted by mikinoz View PostChris said the engine would be in by then!
 Haha, true..Originally posted by Volksee77 View Postnot really as a running engine far outperforms one still in bits
 Well I went to time the cams in this morning.. So first things first, I went and got some bolts I needed for the cam cover.. And some moly grease for the cam lobes..
 Then, as luck would strike me, I found out that my dial indicator attachment wasn't long enough to fit down the bore in the head and screw into the plug hole... Very, very frustrating. I've made an extension and i've got an ejector pin that I will cut to length tomorrow to suit.. A bit of a PITA, but i want to time these cams in properly..
 In other news, here's some pics of #1 piston that came out of this engine and also the contents of the original water pump...
 So... Time the cams in tomorrow.. Then I can put the cover on, get some spark plugs and work on getting this donk in the car....
 Hows the bore look in the number 1 cylinder? Did you get them honed yet? What is the indicator you are using for your cam setup, would be interested in theses process as I love to make sure mines dialed in properly.
 The bores were all pretty worn. That's one of the reasons I bored it out to 82.5mm..Originally posted by alex g View PostHows the bore look in the number 1 cylinder? Did you get them honed yet? What is the indicator you are using for your cam setup, would be interested in theses process as I love to make sure mines dialed in properly.
 I'll take pics when I time the cams in and show you what i'm talking about.
 ..... Oh and for the sake of information.. Standard KR plugs are NGK BCP7ET.
 I couldn't find it anywhere in my info so I had to get Tim to grab the info off ETKA.. I don't know what i'd do without that bearded redneck.. (Here's hoping he reads this! haha)
 hey nice pics, that water pump is still good, just a couple of tubes of metal mend and you'll be able to reuse that lol. One thing to watch though when you get this started you may want to get it running and warm it up then drop the oil fairly soon hey as you never know with all the moly grease etc in there you would hate to block one of the piston oil squirters or something as they don't take much to give up the go and then your running into bigger issues than you want on a new engine77 Golf tarmac rally
 89 porsche 911
 80 Rabbit 4dr
 Hahaha cheers, mate.Originally posted by Volksee77 View Posthey nice pics, that water pump is still good, just a couple of tubes of metal mend and you'll be able to reuse that lol. One thing to watch though when you get this started you may want to get it running and warm it up then drop the oil fairly soon hey as you never know with all the moly grease etc in there you would hate to block one of the piston oil squirters or something as they don't take much to give up the go and then your running into bigger issues than you want on a new engine
 Yeah i intend to drop the oil very quickly.. You never know what got left in the engine and there's all sorts of particles that start floating around after the first fire up..
 Man... What a day!!
 First up, here's my dial tool with the extension I made..
 The moly grease I used..
 Now... Timing the Cams in..
 Firstly.. It's a good idea to wind the crank so that all cylinders are half way down the bore when fitting the cams.. This stops any valves dropping in to say "Hi!" to the pistons.
 When they're in and timed to eachother, wind the cam sprocket 'round 'till the line on the inside of it is flush with the top face of the head (Sorry, i forgot to take a pic of that!).
 The way I wind the cams is by using a belt strap type oil filter tool around the sprocket. This also works rather will for tightening the retaining bolts on the sprockets and pulleys.
 Before I go on, here's some pics of the TDC pointer I made today:
 Now, fit your dial indicator.. (I should mention that you can also use a piston stop and a degree wheel in basically the same fashion, but I like dial indicators and I didn't have a piston stop.. ) )
 Wind the crank until the piston pushes on the dial and reaches TDC (The point where the dial winds up to its highest point) and zero it.
 Now, normally you have to account for piston "dwell". Piston dwell is the time the piston remains, for all intents and purposes, still at the top and the bottom of the stroke. This is affected by rod length and stroke length. This is hard to explain it text, but basically, the longer they are the more dwell you will have. Given that this engine has a relatively short stroke and only 144mm rods, it has (for the purpose of timing) no measurable (by these means) dwell. So that makes picking up TDC really easy.
 To pick up TDC on an engine with a measurable amount of dwell, you wind the crank clockwise past TDC until the indicator moves a given amount.. So lets say 0.03mm. At that point, mark your pulley where the timing marker is sitting. Then wind the crank anticlockwise until you go past TDC in the other direction and the indicator moves 0.03mm. Mark your pulley again.
 Half way in between these two points you just marked is TRUE top dead centre.
 Now you can mark your pulley, like so:
 I also like to put a dob of white marker on it, so I know which one to use.. Given that this pulley has the original marker for the 1.8T..
 More to come.. Last edited by Preen59; 13-02-2011, 07:15 PM. Last edited by Preen59; 13-02-2011, 07:15 PM.
 Then on to fitting the timing belt, etc..
 Next up, fit the rocker cover and ignition leads..
 Now, what to do with those pesky leads.. I know.. It's bracket time!
 Cam card..
 Light coat of primer in the 'bay..
 Now, time to put the engine in the car (with the gear box!)
 Here's a few shots from underneath..
 INA Alternator kit clearance..
 Now just some shots of the bay..
 Here's an issue to resolve.. Maybe a 90 degree dizzy cap?
 To say I'm happy would be an understatement.. I'm ****ing stoked!!
 awesome stuff chris, this looks super smooth and like it came from the factory in there mate, well done indeed, what kind of overlap did you set on the cams if any may i ask? That TDC crank indicator is awesome, don't suppose you want to make another lol. Have you thought of going coil packs and ignitors for your spark run by a crank trigger wheel so you can remove the dizzy? (thats what i'm doing) or even rig up a trigger off the dizzy drive (not hard) then you can junk the dizzy and get that space back. The INA kit looks super smooth and made for your car, you did a great job slimming it down hey. On another note i see you have Ashley headers (correct me if i'm wrong), how does the clearance look for the steering boot on the RHD cars?
 Keep it up mate, at this rate you'll be getting noise in weeks the hardest part now must be paint hey?77 Golf tarmac rally
 89 porsche 911
 80 Rabbit 4dr
 good work Pman. top stuff. Looking pretty good in the bay there.
 I'v seen some people just run two ports off the MC into some T pieces behind/under the booster., that could be one solution. Or just test Tim out and see how good he is at making brake lines!
 Are you going to leave the Gbox in that finish? I can't help but think that some wheel silver might look better? :/
 Funny this came up, I am looking to get one of the side entry caps. There is a few on the eBay at the moment.
 Citroen BX C15 LNA Visa Peugeot 104 205 Distributor Cap (eBay item 130469567219 end time 27-Feb-11 08:00:22 AEDST) : Vehicle Parts Accessories
 The Bosch part is 1235 522 332 and this is a replacement.
 Let me know if you want and I'll order 2.
 I found a post on Vortex where alexg was asking the part number too from 2006!
