Mk1 16v Project
 Mmmm not exactly....Originally posted by DaveMack View PostPoured into moulds and then machined ... maybe.
 Dave
 Forging is the term for shaping metal by using localized compressive forces. Cold forging is done at room temperature or near room temperature. Hot forging is done at a high temperature, which makes metal easier to shape and less likely to fracture. Warm forging is done at intermediate temperature between room temperature and hot forging temperatures. Forged parts can range in weight from less than a kilogram to 170 metric tons. Forged parts usually require further processing to achieve a finished part.
 Basically you can make a denser part than with a casting process. Which makes the grain structure tighter, and therefore stronger. Last edited by Preen59; 03-08-2008, 03:11 AM. Last edited by Preen59; 03-08-2008, 03:11 AM.
 I would fit Wossner 11.5:1 - they are by far the best quality and price now and this is a better compression for a road car (mine detonated with any reasonable timing and pump fuel...). Bildon sell them for good money, but they are assholes...Originally posted by Preen59 View PostSmall update, decided to go to forged 82.5mm pistons.
 I figured with all the other work i'm doing, i'd be crazy not to.
 Any suggestions on a particular brand?
 You can by them direct but the Euro is hardly a star performer at the moment
 I may have missed it, but what have you done with the rods? Reason I ask is that they're perfectly good balanced up and not worth the expense of upgrading (although the Scat ones are now very cheap).
 Thanks for the advice. Although I have been told that it's better to take the material off the head and or block than to use High Comp pistons due to the fact that the high crown spreads the charge and can cause detonation and make the charge burn time longer. What's your take on that? Or due to the Head design, is it better to run high comp pistons? Also, i was thinking of only going 11.0:1, or would 11.5 be ok? In my experience my last 8v engine had 11.0:1 comp and it would detonate if i wasn't careful about the fuel/ignition.Originally posted by Valver. View PostI would fit Wossner 11.5:1 - they are by far the best quality and price now and this is a better compression for a road car (mine detonated with any reasonable timing and pump fuel...). Bildon sell them for good money, but they are assholes...
 I've got CRS Chromoly H beam rods out of the states for it. Rated for 600HP, shot peened, stress relieved brass little ends honed for floating pins ARP 3/8 L19 bolts etc etc and they were 300 bucks landed at my door. It was cheaper to do that than to bring my old rods up to scratch.
 Thanks for the advice. Last edited by Preen59; 03-08-2008, 05:47 PM. Last edited by Preen59; 03-08-2008, 05:47 PM.
 OK.. this is what i've found so far to be the best prices for brands i trust..
 Bildon Motorsport
 Wössner 16v forged- US$549
 Drag Performance (Ebay)
 Custom JE 16v forged- US$600
 Both come with rings, pins and clips..
 I'm assuming Bildon will do wossner custom comp for me..
 This Drag Performance mob will do any bore size any comp ratio in JE's for that price.. The only thing is that I don't know if the JE's price is for coated or uncoated.. And i haven't asked yet..
 Hahaha, yeah i'll email the guy tomorrow. And thanks man.Originally posted by WABIT View Postwell get it happenin mate, the only way your gonna know is if you ask questions mate
 great progress BTW
 dom
 Wossner will make anything for you www.woessner-kolben.de/ and I would definitely run the correct pistons rather than decking the hell out of the block or head - meaning you have wrecked them for any future work, especially if you do a gasket and have to shave the head again!
 Ok thanks for the link. Yeah i figured as much about the comp, but wanted a third opinion.Originally posted by Valver. View PostWossner will make anything for you www.woessner-kolben.de/ and I would definitely run the correct pistons rather than decking the hell out of the block or head - meaning you have wrecked them for any future work, especially if you do a gasket and have to shave the head again!
 Not sure whether to go with Woessner or JE yet, i'll email this bloke doing the JE's for a good price and see what he says about the coating.
 Thanks.Originally posted by Valver. View PostP.S. Nice rods  Not bad for the price.. Just a little cheaper than carillo's. Not bad for the price.. Just a little cheaper than carillo's. . .
 Good idea..Originally posted by WABIT View Postmaybee try and get in contact with guys who have fitted JE pistons and see what they have to say, theres bound to be some running them on u.s vortex
 dom
 Find out for me Dom..
 Im running JE forges in my 16v but you have even more forged piston options than mentioned such as Mahle and Wiseco i am about to order two sets of Wiseco forged pistons for the twin eng soon for $439 a set 0.40" oversize 8v and thats coated with rings. Check out www.importperformanceparts.net they have Mahle, JE and wiseco. Wiseco are $439 and JE are $489 a set with rings you cant go wrong and their is a choice of oversizes and compression ratios aswell! What are you going to do with the cast ones from techtonics now?sigpic
 Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
 Mk1 twin eng twin turb
 scirocco gti 2.1l 16v turb 6spd
 Audi A4 B5 1.8t
 I know i have more options, but i like JE and i have confidence in them. I checked out Import performance parts before. They only quote 2.0l stuff and not the comp ratio i want.Originally posted by twin eng, twin turbs View PostIm running JE forges in my 16v but you have even more forged piston options than mentioned such as Mahle and Wiseco i am about to order two sets of Wiseco forged pistons for the twin eng soon for $439 a set 0.40" oversize 8v and thats coated with rings. Check out www.importperformanceparts.net they have Mahle, JE and wiseco. Wiseco are $439 and JE are $489 a set with rings you cant go wrong and their is a choice of oversizes and compression ratios aswell! What are you going to do with the cast ones from techtonics now?
 I'll be selling the cast pistons..
 Edit: Just emailed IPP anyway regarding the pistons i'm after, so we'll see what happens.Last edited by Preen59; 04-08-2008, 10:36 PM.
 Figured i'd post some pics of the head lining when we did it.. All that time ago..
 Grey velour. My mum made it and her and i fitted it. Not bad for a Janomie sewing machine huh?
