The new shed!
  • #16
    The new shed!
    I did my garage in a 2 part epoxy, applied it with a roller with my dad and it only took us about 2 nights. Ours would be about the same size as yours I reckon.
    • #17
      The company I worked for earlier in the year did specialist flooring. As you said acid etch and/or a grind is essential for a long lasting floor in an industrial workplace.
      As foff said the 2 part can be done at home with some rollers very easily, its just a matter of mixing up and applying.
      If ya want it to look funky you can add glass for grip and make it pop.
      • #18
        I like it a lot !
        • #19
          Well, to be fair the workshop we did was massive. We did it with rollers and it was Very time consuming. A floor if this scale should be a lot easier.
          • #20
            Def recommend an epoxy, you'll regret it later if you don't, especially if you plan on working on any cars in there.
            Just having a quick squiz at the m2, you should be looking around $900 materials for a decent 3 coat epoxy system.
            It should be done over 3 days minimum, 1 day to pressure wash, 2nd to apply sealer and first top coat, 3rd for final topcoat.
            From a spurt
            Polo GTI MY2008
            Build Thread
            136.09kW and 305.28Nm torques, Dynapack Hub Dyno
            • #21
              From a spurt
              Woo, a spurt! Thanks for the advice, dude.
              • #22
                Slab layed yesterday. Oh hells yeah!
                They're going to come back to run some cuts through it and render the edge beam to pretty it up, too. I thought that was pretty sweet. As always, you get what you pay for.
                • #23
                  sweet. Nothing like seeing plans coming together. Hope you are having a shed warming BBQ once this baby is up....
                  My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
                  • #24
                    Is the bear a catholic?
                    • #25
                      shed build, nice!
                      • #26
                        interested to see how/where the cladding finishes at ground level.
                        we would pour slabs post cladding going up to give it a more dust/vermin tight finish
                        Bora gone
                        Vento VR6
                        MKIV GSW TDI
                        7P Touareg TDI
                        • #27
                          They finish about 80mm below the edge, I think.
                          I've heard they do them that way down south (VIC and SA). We don't really have dust or vermin problems here. The only issue is keeping the joint warm in winter. Hahaha.
                          • #28
                            Shed's up.
                            Next up, paint the floor.
                            • #29
                              Mmmmm yis.
                              Dat's the stuff right thur.
