Matts MK4 GL Respray & VR6 Conversion
  • #76
    Spent an hour cleaning tonight, impressed myself with how much I got done.
    Another couple of hours and it should be looking the goods.
    • #77
      • #78
        Slowly
        Bracket cleaned and painted
        V5 alternator not fitting - need Bosch style that dips more in the middle
        • #79
          blast!
          • #80
            I think I've finalized my parts list
            Engine/Gearbox:
            Exhaust manifold gaskets
            Intake manifold gasket
            Dipstick
            Non-aircon belt
            Coolant temp sensor
            Belt tensioner - V5 tensioner is different
            Water pump - didn't need replacing but may as well
            SAI blockoff
            SMF and clutch - 12v vr6 parts
            CV boots
            General:
            Banjo bolts
            FSB bolts - lost these when I removed mine
            Cloth webbed tape - plan on moving some things as my battery is in the spare wheel well
            Red split wire loom - make the coil leads prettier as the intake manifold is going gloss black
            Suspension etc:
            Urethane real coil spring isolators
            Urethane control arm bushings - This and below item are wheel hop eliminator kit
            Urethane dog bone inserts
            Outer tie rod ends
            Rear axle bushings - need to take half of it off to change one of the brackets, so may as well
            Upper strut bearings
            Ball joints
            H&R 26mm FSB - need to put one in as I chopped the old one out when I was lower - plan on getting the 28mm adjustable RSB at a later date to help with the known understeer
            Ball join extender/camber control
            Powerflex black strut top bushing - sick of replacing the standard tops so often (one is already cactus at 3000km's)
            Brakes:
            Front - already have 312mm - going drilled and slotted rotor
            Rear - drilled and slotted rotor - pads to come at a later date
            Braided lines front and rear
            Tools - need to get the job done somehow:
            Spreader tool
            Long reach triple square set
            Brake piston retraction set
            Tie rod separator
            Torque wrench
            Other:
            Drivers side engine loom (with 4 o2 sensors ><)
            Drive by wire throttle body
            Drive by wire accelerator pedal
            2x injector plugs, one is missing one is broken
            Reason for all the suspension parts - being low ****s your bushings, not low anymore, weird clunks, track time.
            Track time will come after new coilovers & RSB, looking at H&R - hopefully from a local source as postage is killer from O.S - not to mention import tax.
            Hopefully this will give you people some insight as to what's going to happen apart from engine side of things.
            Confirmed that I've got another car to use from tomorrow - get to start pulling the Golf to pieces
            • #81
              This make me happy!
              • #82
                Good work!
                Bora gone
                Vento VR6
                MKIV GSW TDI
                7P Touareg TDI
                • #83
                  I hope so Woody
                  Cheers Dylan
                  Last night
                  This morning
                  Engine is ready to pull out but I need an angle grinder to chop the exhaust (no flange around cat area)
                  • #84
                    Woody was chasing one the other day too, maybe see if he ended up scoring one?
                    Bora gone
                    Vento VR6
                    MKIV GSW TDI
                    7P Touareg TDI
                    • #85
                      it has begun! excellent.
                      • #86
                        Certainly has
                        Got my hands on an angle grinder tonight, such a pita to chop the exhaust.
                        Needed to drop the subframe again for the exhaust to clear but...
                        It's out!
                        • #87
                          yay!
                          Now the real fun can begin.
                          • #88
                            yay!
                            If you say so , may need to remove the dash for DBW conversion, checking if someone has a loom available.
                            Removing the dash is not so bad - removing the steering wheel will be a first for me and apparently a pita but the rest is straight forward
                            Dash removal - Bora - uk-mkivs
                            But at least if I swap the dash loom, I can assume everything will be working without swapping wires around
                            • #89
                              Exactly what i will be doing on my 1.6 when the 1.8t goes in, dash and heater box swap too for climate control shall be fun! Will be watching this build closely
                              MY MK4 BUILD
                              • #90
                                The steering wheel removal isn't too bad Matty. I sat and watched Pete swap out Megan's ****ty one for a Bora Sport one in 5 minutes. Provided you have the threesquare tool and some patience, it's fairly agreeable.
