Originally posted by WABIT
View Post
Mk 1 Diesel Project
Don't worry guys, prep was all there. Nice and rough, and all metal too.
Watch you don't put too much heat in when you're grinding the welds off.
Grab a flapper disc for your grinder too so you don't gouge out the surrounding metal. They're about the same price as a grinder disc just gentler and a much smoother finish.
You need to keep the panel cool as possible to avoid distortion. I use a soaking wet rag to take the heat out between welds and when grinding.
Other than that it's all practice.
Make sure you're wearing all the safety gear and have a bucket of water or a hose nearby. Remember that you can't see flames through the visor and you may not know that you've set yourself on fire. (Seriously)
and like Dom says, surface preparation is everything, use your new flapper disc to clean up the panel for a good area around the weld and make sure your earth clamp is attached to freshly cleaned metal too.
For what you're doing, use short bursts on the trigger, wait 'till it's no longer glowing red before you pull the trigger again. When you're begining a series of spots will be easier than a long stitch, especially in rusty sheet metal.
We'll have you lead wiping in no time.
Pete79 MK1 Golf Wreck to Race / 79 MK1 Golf The Red Thread / 76 MK1 Golf Kamei Race Car
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
good job jarred i knew you didn't need me to do it
glad to see some work getting done
"The Stu likes this"
You're going to need to clean a larger area than shown on your pictures.Originally posted by Jarred View PostDon't worry guys, prep was all there. Nice and rough, and all metal too.
The smoke and fumes from the burning paint will affect the weld otherwise.
You're going to have to remove the burnt paint anyway so it's better to get it out of the way up front.
Roughness doesn't matter, in fact your'e probably making the job harder by removing metal along with the paint.
Which process are you using? Gas or gassless MIG?
Good on you for taking a crack at it, that's how to learn these things.
7? MK1 Caddy
12 Amarok
Using Gas MIG Pete.
I don't remeber burning too much smoke, but I'll look out for it extra tomorrow.
Had all the safety gear on too.
All good advice though Pete, I'll take as much as I can, thanks!
Yep, need to cover up any bare skin too or you'll be sunburnt.
I learned this from experience. It isn't fun.
7? MK1 Caddy
12 Amarok
Yeah rayburn is REALLY painful.. Especially on the inside of your leg when you're welding in shorts all day...Originally posted by Peter Jones View PostYep, need to cover up any bare skin too or you'll be sunburnt.
Pete
Good onya for having a crack.. You'll probably make a bit of a mess to start with, but you'll improve and it's all a learning experience..
A man who has never made a mistake has never made anything.
I inherited a pair of arc welding goggles from my grandfather and used them the first time I tried out my Arc Welder. Needless to say my face was very very burnt.Originally posted by Preen59 View PostYeah rayburn is REALLY painful.. Especially on the inside of your leg when you're welding in shorts all day...
Those helmets do a lot more than keeping the bright light out of you eyes.
7? MK1 Caddy
12 Amarok
Hahaha.. Whoops!Originally posted by Peter Jones View PostI inherited a pair of arc welding goggles from my grandfather and used them the first time I tried out my Arc Welder. Needless to say my face was very very burnt.
Pete
Yeah, I was young and foolish once too.
I guess there's a reason you can't buy Arc Welding goggles in the shops anymore.
7? MK1 Caddy
12 Amarok
ahhhh you mean this one??!?Originally posted by WABIT View Posthey dude.... wheres that picc u took haha
dom
who can geuss what face dom calls this one??!?
yes that is Dom rolling the lips on my arches. Wonder what I'd need to do that for??.. hmmm....
I also kept at it with the welding. ran out of Gas so not quite finished yet.
Thanks Pete for the tips, esp the flapper disk, worked a treat! - and I never would have thought of it either.
Got some shaving done. I didn't take pics of it all, cause it'd be boring, but you'll get the full effect once the car is done!
yes that'll be touched up, don't worry..
