Update as promised.
Finished off the front hubs and loaded the bearings.
You're looking at 16v MK2 Golf Hubs, ARP wheel studs, 19 mm ball joint & extender, MK2 rack arms.
I've got an old MK1 outer CV tightened up in there so I can roll the car around without damaging the bearing.
The MK2 steering arms are a little long, there's still some sorting out to be done there.
280mm Euro Spec discs.
Note the welding burn on the inner guard, I resprayed those bits today, it's from my pedal box adventures.
Girling 60 caliper fitted up. No pads yet I'm still trial fitting things at this stage.
I'm going to get these wheels widened now I know what offsets will work. I put these tyres on just for the moment.
Those calipers are a close fit but work well inside the wheel.
Here's what I did to the pedal box area. I just hacked out the tin and welded two diagonal brackets straight to the bulkhead.
The tin isn't structural it's mostly there to hold the carpet up and trap water so I'll just edge it with some pinchweld.
Back on the ground!
Minus the bracketry. Fitting up a couple of guards to check wheel/tyre clearances.
It's lower than it looks, the wheel arches have all been moved up which make it look high. Front valance has been cut off too.
Frame horns are about 6" off the ground with no motor fitted.
6 Inches is way too narrow. Plan is to go to 8" which is a CAMS/class thing and also about the widest tyre I can heat up properly in a car this light.
Final wheel size is 15 x 8 et 0 - et 10.
After modifying just about every part of the suspension and assembling by eyeball what are the odds that the top plate would read to the exact camber measurement?
-3° on top and -3° below. I was a bit nervous about the range of adjustment I'd have with this setup but it look like it's all worked out OK.
-3° seem to be about the max and I can get it as far back 0°. Pretty much the perfect range for me.
Caster measured at +4°. I need to do some research on the ideal figure but that seems in the ballpark.
Back on the ground!
