G-8VXWWTRHPN Potential Issues with Waterless Engine Coolants - VWWatercooled Australia
  • Potential Issues with Waterless Engine Coolants
    Interesting article:
    Article | Oilem - Lifting the lid on the market
    Present: Superman BMW F30 330d M Sport + Toys
    Ordered: Red Tornado VW Golf Mk7 R 5 Door + DSG + Toys
    Not a problem for VAG engines they don't use the waterless coolant.
    The ethylene glycol coolant mixed with water up to 60:40 ratio are actually increasing the boiling point of the coolant mix and when the coolant reservoir pressure cap is working properly, it will raise the boiling point above or close to 120deg.C (it varies between the brands of coolant, I've seen some claiming 160degC).
    Use water mixed with some aftermarket magic as a coolant in your engine at your own peril, you will regret that later.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      I found the Cetane additive article on that site quite interesting. Shame that it ends in an advert, though.
      Resident grumpy old fart
        Thanks for sharing this info VW7R.
