Originally posted by Lucas_R
View Post
Coolant Spec (manual vs reservoir)
Originally posted by avf383 View Postwhat vacuum filler did you use?
Draper 09544 Coolant Vacuum Refill Kit : Amazon.com.au: Home Improvement
This one appears to be the exact same tool and is cheaper OEMTOOLS 24444 Coolant System Refiller Kit, 5 Adapters, Eliminate Trapped Air, Test Radiator and Heating Core Lines for Leaks, Vacuum Fill Coolant Tool, Vacuum Leak Tester: Automotive: Amazon.com.au
Originally posted by Lucas_R View PostI used the Draper one which worked well. I have plenty of G13 coolant and demineralised water left over so ill be doing a coolant flush on my Mk7 GTI over the Christmas break too
thank you much appreciated
