Seat Belt - buckle retaining Button
  • Seat Belt - buckle retaining Button
    Hi, Where can one get the plastic buttons on the seat belt that stops the the buckle from dropping to the ground?
    I have spoken to Repco and they know exactly what I'm after but do not sell them.
    Cheers.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
    99% sure vw dont sell them seperate to the belt....scrap yard?......VDUB...
    BRISBANE / GOLD COAST
      scrap yard will not do - they are a one use item. bring 2 parts of button together (pin and button) then join by melting the pin.
      i have found them on ebay but trying local 1st.
        People who sell webbing can supply a plastic piece that can be fitted to the belt that can be used as a stop. It is a bit like an S with the belt going under and over. It has to be soft as it can bear against you.
        Failing that try a special seat belt manufacturer. They have to provide these things when they make a custom belt. These are used for wheelchair belts and the like.
