Hi. I have a VW OEM towbar (VGA 803 921 G504 ) for my Mk5 Golf.
What is the torque nm to fasten this towbar please? It uses M12 hex bolts, but I'm not after torque specs for M12 8.8 hex bolts (which can run very high). Bolt length I have 40mm and 25mm to choose from. 25mm bolts reach to nut limit (with spring washer and flat washer bolt side) but don't extend further.
The towbar is fastened in four places. From Bunnings i got 8.8 high tensile M12 Hex Bolts, 12mm 8.8 high tensile washers (pinnacle brand) and zenith brand zinc plated spring washes - also from bunnings (don't appear high tensile).
I have searched online for the torque specs of tht 4 M12 Hex bolts, but find too many different torque specs for different towbars & M10 hex bolts. to this one.
I don't want to over or under torsion the bolts/washers/spring washers, nuts, bar and golf frame. Thank you
