Vcds changes
  • #16
    Isn't auto door lock available as standard from the infotainment menu?
    • #17
      Originally posted by blueSup View Post
      I couldn't get the TSR to work on mine. The coding seemed way off on a few of the steps.
      I used this site for the window/sunroof stuff (https://sites.google.com/a/naturalne...dow-open-close)
      Did you you have any problems with the sunroof? I can't get mine to open from the key instead of tilt.. it's one of the easiest vcds changes I've seen yet it's he one stumping me ATM!
      • #18
        I certainly have not seen it in mine but will have to check
        Sent from my SM-T800 using Tapatalk
        • #19
          I didn't go looking for a way to open it fully. It just tilts open. If I keep holding the button the sunshade retracts fully. The same for closing - I have to hold the button until the shade closes fully as it won't automatically close all the way.
          Looks like an investigation is due this weekend.
          • #20
            Mine fails to read any coding for Controller A5 as well. It comes up all zeros.
            blueSup: your observation regarding the Frt Sens. Drv. Assist control module @ address hexA5 may be because the module is correctly reporting a zero sequence for the code-string.
            I'm not sure about the Skoda Superb, but the latest generation BCM for both the Golf mk7 and Audi A3 (both also built on MQB platform) similarly report a zero sequence for their code string. In these modules, the boffins @ VAG have transferred the software switches that were previously in the code string to adaptation channels.
            Might be worth making an admap for the module and checking if the adaptation channel names refer to previous code switches.
            Don
            • #21
              I've had a Ross Tech MicroCAN cable for a while, have done:
              Auto high beams (light assist)
              Persistent seat ventilation/heat settings on drivers side
              Fan speed LEDs when climate control is on
              Audi manufacturer setting, though I didn't really notice a difference with this
              Off road menu
              Traffic info (no signal up here though)
              Traffic sign recognition
              I really liked the TSR especially the ability to set alerts when over the last seen speed sign by a certain amount, but could only get it to work with an annoying warning every time the car was restarted which also logged an error in the vehicle menu, so turned it off again. Has anyone got it to work without issue? It would also sometimes decide the yellow recommendation signs such as 20 for a speed bump were a speed limit and change the sign, as well as occasionally deciding something in its field of view warranted changing the sign to 100 in a 50kmh back street...
              Also used it to run a calibration on the DSG, after which it shifted much nicer. Tried a few other things such as increasing the number of blinks for the first indicator pressure and having the DRLs only partially fade instead of turn off when indicator was on, but could never get the first to work and stuffed the second up so bad I immediately changed it back and left it alone
              • #22
                The TSR works for me without error, but it originally had an error each time the car started. I'm currently running from camera only but plan to switch back to "fusion" mode on the weekend. If I get the time on the weekend to switch back I'll also document all of the steps.
                • #23
                  Ok I woeked out what you were referring to. That Autolocking in the stock menu is when you start driving it locks the doors automatically once you get above 7km/hr. I think it's the same trigger point that deactivates the camera if you put it in reverse and then drive mode.
                  The auto locking that I'm talking about enabling is when you walk away from the vehicle it will automatically lock the doors xx sec after you close them as long as the key is not still inside. Far too often I leave it unlocked by just walking away.
                  Sent from my Pixel XL using Tapatalk
                  • #24
                    Ahnof course... I've even read about that feature - often referred to as slam to lock. I should have realised!
                    • #25
                      As mentioned, I switched my TSR setting back to the default Fusion mode, and promptly lost sign detection.
                      I typed up some hints and settings for TSR and high beam assist and popped them here - Adventures in VCDS.
                      • #26
                        If anyone is having problems with High Beam Assist (HBA) then try this guide as it's the steps I followed.
                        • #27
                          I am having problems with mine, and thanks ill try that document
                          • #28
                            Thanks bluesup for the instruction. I managed to get it working using obdeleven. However, there is an additional step of adding FLA to Erweiterte_Fernlichtsteuerung in (09) central electrics
                            Sent from my LG-H990 using Tapatalk
                            • #29
                              Can you share your obdeleven screenshots or export your history log relative to the hba and share.
                              • #30
                                high beam assist didn't work on my car. I got a failure each time I attempted to operate it
                                they created a new app for me and it seemed to fix it. stupid me in my excitement didn't do an adaptations map before and after
