Engine Warning Light
  • Engine Warning Light
    Hey Everyone,
    I currently have a 2010 Skoda Octavia RS Liftback DSG 147TSI.
    I had my engine warning light appear last month. And it was hooked up and diagnosed as a broken inlet manifold. This has since been replaced. However the light can be decoded away but comes back on within a few minutes of driving. Does anyone else know what could cause this?
    I've had Skoda and VW mechanics look at it. And they all say that there is nothing wrong with the car and they don't understand why the light keeps coming back.
    It will be greatly appreciated if anyone can help. Once the problem is solved it will be up for sale.
    What's the code?
      I'm not sure I'm sorry. I can get that on Monday when service is back
        Fuel pressure fault most likely? We really need the fault codes in order to help you out mate, P.S: If your engine light is on, it's not okay, something is wrong, the VW tech should know this..
          Get it in writing that they will accept responsibility and costs if something were to go wrong in the near future.
            Ok so the error number is P2015
              Intake manifold flap failure.
                Which is what he said was replaced in the beginning so obviously something else is up around there.
                  18447/P2015/008213 - Ross-Tech Wiki
                  A few potential solutions in there.
                    Hey guys. I rang my Skoda Service department and they said that they have another solution to remove the light.
                    If it does happen to be the sensor. Would you know what it would cost??
                      No idea.
                      Best to take it up with the dealer, and see what they can do for you.
                        Using 98 fuel? i put in 95 fuel (Australia) and my Yeti started idling quite rough and engine light came on. Filled back up with 98 and problem solved. Had it diagnosed at the time and i think it did come up with a problem related to the manifold, or maybe not also...
                          I only put 98 in it. I'll be seeing the service dept today at 2
