Originally posted by Martin
									View Post
		You're dead right. While increasing the rear roll stiffness relative to the front helps make the car "point", most drivers can't handle the lift off oversteer that is the result - especially with the big "solid axle conversion kits" that a lot of people fit. I've been on a cruise where an R32 ended up off the road due to this.
On tight circuits, I run my rear anti-roll bar at a stiffer setting but for fast circuits and road usage, I back it off for more stability. And I only added the rear anti-roll bar in conjunction to having a stiffer one fitted to the front so that the balance was maintained with the rear bar in the lightest position.
The legendary Peugeots of the early/mid '80s were terrifically responsive because lift off oversteer was designed into them. But they're not allowed to build cars like that any more - too many drivers would end up in ditches and walls due to the dumbing down of cars with driving aids to suit the lowest common denominator (ESP/ABS/TC).
					Originally posted by brad
									View Post
		That said, a lower grip tyre can be hugely entertaining as long as it is predictable and progressive when it reaches its cornerning limits
