Interesting tyre history Brad!
It's more than switching radials, these are directional tyres with an asymmetric tread
Due to a mistake at the end of a track day I ran the front tyres on the wrong side for 5k - only noticed during a visual inspection
Most of the guys racing Mazda MX5's using R rated semi slicks (which are directional) intentionally swap sides trying to milk the most out of a set - no problems
With regard to tyre rotation on FWD I have been running a different strategy for the last 3~4 years
Rotating the tyres wears out the entire set
So I leave the rears alone, they are good for over 80k
I go through two sets on the front to one set on the rear
So I use 6 tires in a similar time/distance to using 8 with regular rotation around the car
You do have inspect the tyres and make sure you don't have alignment problem - but we should be going that anyway
(My habit of charging at roundabouts puts a little pressure on this strategy creating the need to balance front wear side to side)
Originally posted by k_rider
View Post
