118TSI Daytime running lights coded at dealer
  • #31
    beware of the vagcom cable. its not a genuine cable, its pretty much a rip-off of the rosstech. their support is good, but only supports older versions of VCDS, which may mean youll miss functions or function labels. yes, I had one. ended up shelling out for the genuine one and ive never looked back.
    to the look, I like the DRLs down low like that. and yes LED ones would help significantly.
    do they turn off at night or dim?
    • #32
      They turn off if the lights turn on.
      Interesting you say about the software as I use the one I downloaded from RossTech direct so it def not kissing anything. Only thing is that its not the full v11 I am running the older one but still has all the functions I need
      • #33
        Originally posted by hitman View Post
        pic of what the DRL's look like, not too shabby. Would be cool with some CANBUS LED's though.
        Pretty sure there's a kit on SuperSkoda.
        Not including hers...
        • #34
          On a side note , I am also considering getting a VAG cable but cannot seem to find the connection with in my Octavia MY12 .
          I have reviewed online manuals as show below:
          Skoda Workshop Manuals - Octavia Mk1 - Test signal from PAS pressure switch
          Skoda Workshop Manuals - Octavia Mk1 - Connecting vehicle system tester V.A.G 1552 and selecting the address word for the convenience system central control unit J393
          Skoda Workshop Manuals - Octavia Mk1 - Connect vehicle system tester V.A.G 1552 and select address word 01 for engine electronics
          http://www.matthewames.co.uk/briskod...s/51175020.pdf - 90-40
          Skoda Workshop Manuals - Octavia Mk1 - Test sequence
          Its probably right in from of me the whole time and I am Kissing
          Can someone please get me out of my misery and point me to the right direction, a photo is welcome too.
          • #35
            ok you know to the right of the steering wheel, there is the pocket you can put..... well, anything that will fit in there.
            its below that, but above the bonnet catch release. tucked under the lower half of the dash shroud.
            its a purple plug
            • #36
              Yep it sure is.
              You'll have to get down and dirty on your hands and knees to see it
              • #37
                Yep it sure is.
                Best get wife to do it then Kill two birds with one stone ROFL
                • #38
                  I am sure I looked below the steering wheel, also took that pocket out.
                  guess I missed it and will see if my Wife will go down and dirty on her hands and knees to check if she can find IT
                  • #39
                    No need to remove the pocket, its under the dash below that, it may have a cover on it but I doubt it
                    • #40
                      Guess what, I found it. Don't I feel stupid
