Originally posted by BottomScratcher
View Post
Skoda has a list of approved tyre sizes and fitments (with the corresponding load index and speed symbol) for each of its vehicles in the workshop manual. One would need access to ElsaWin or ask your nearest friendly dealer to print out the list.
View Post
View Post
View Post
Try not to focus too much on the 'headline figure' of 300 km/h.
Having said that, it is uncommon for most 225/40 R18 summer tyres to have a speed symbol of V (240 km/h) or less. Most summer tyres in that size tend to be W-rated (270 km/h) or Y-rated (300 km/h).
View Post
Every tyre size has a corresponding load index as specified by the ETRTO (European Tyre and Rim Technical Organisation):
A 225/45 R17 will have a load index of 91 (standard load) or 94 (extra load).
A 225/40 R18 will have a load index of 88 (standard load) or 92 (extra load).
Though there would be less confusion if the placard included the respective load index for each tyre.
You may see some slight variations in the load index depending on which standard the tyre was manufactured to (ETRTO = Europe, TRA = USA, JATMA = Japan are the three major associations) but this is uncommon for passenger car tyres sold in Australia, so you are unlikely to encounter this.
View Post
3385 kg: Gross combination mass (GCM) i.e. permissible gross mass with trailer
1060 kg: Maximum permissible front axle load
950 kg: Maximum permissible rear axle load
650 kg: Permissible unbraked trailer load
This information should be in the owner's manual.
Given the odds, fitting tyres with a lesser speed symbol than the original tyres (within reason) won't have a noticeably adverse affect on safety - particularly if you drive in a conservative manner.
