At over 300,000km oil consumption has gotten out of control so time to replace engine.
Looking around was able to source locally a 140kw diesel engine out of a Tiguan that had less than 27,000km so i bit the bullet and went for it. new engine came with inlet manifold, exhaust manifold, turbo, fuel filter, coolant bottle and all coolant hoses, full engine harness.
old engine was 135kw CUPA
new engine 140kw DFHA
As I haven't seen much detail on this kind of swap I will document my findings as I go
Differences found so far:
Wiring harness has different plug at ECU end, no problem swap engine looms over, in doing so found that the DFHA utilises a EGR valve on the inlet, which explains why these engines have 5 exhaust ports on the manifold, no issue, will retain plumbing and existing EGR cooler / EGR system, leaving the hot side EGR closed (old inlet manifold is blanked across the port)
All sensors apart from the DPF pressure sensor are identical, DFHA DPF sensor appeared to have two sense line connected (assuming before and after DPF) where the CUPA only had the one (DPF inlet) with the other port open to atmosphere.
Minor changes to the coolant pluming around the EGR cooler, utilising existing pipes to match the old way the cooling system works.
no. 3 cylinder glow plug has integral pressure sensor, easy fix replace glow plug with standard one.
New motor came without a flywheel, no problem I though just swap flywheels over, wrong CUPA engine utilises 6 bolts to hold flywheel on, DFHA motor uses 8 bolts, this is the point I am stuck at trying to find out what flywheel will fit the crank and sit inside the transmission bell housing. have found that many 8 bolt wheels are 290mm in diam, whereas existing one is 280mm diam.
Don't really want to go down the road of fitting a DQ500 transmission, mainly because of the software issues, unless changes can be made with VCDS.
Anyway this is where I am at. any parts guru's out there that may have some insight about the flywheel would love to hear from you.
