Hi all,
Looking for some help if possible!
I have a Mk3 Octavia pre FL (2017) that has quite a metallic rattle at about 1800rpm and at light load. Took it to my independent VAG garage who said the wastegate actuator rod was loose and showed me when it was up on the lift. Took it to Skoda dealership who also confirmed wastegate rattle on a test drive.
They called Skoda Australia and the technical department said it was 'normal' and if it didn't throw any codes then the car is deemed serviceable. Can the rattle get progressively worse and lead to codes or failures?
I've read it is quite common on VWs and Audis and that a clip is sometimes used but the Skoda dealership said they aren't the same engines and not applicable. They also charged me $125 for them to inspect and call Skoda.
Are there technical bulletins relating to this for Skoda vehicles or am I wasting my time and breath?
Any help or info is greatly appreciated!
