G-8VXWWTRHPN Cupra mini build thread - Blanco Gringo! - VWWatercooled Australia
  • Cupra mini build thread - Blanco Gringo!
    Welcome to the 'Blanco Gringo' (white boy) little 16v project that a mate and I have started on.
    The basics;
    - 16v 2.0 purchased recently. Ran ok, not fantastic but shouldn't be so hard to sort out with some maintenance
    - Cupra (so it has the half leather)
    - OMP rear and front tie braces
    Already done;
    15" BBS RS
    Alpine stereo install including amp/sub
    Coming soon;
    H&R Comfort Cup Kit
    Garlock EPROM
    Replace all brakes to slotted and fast road pads/braided lines
    A proper exterior detail
    Not much else to mention. Needs a new lambda probe and some knick knacks like an aerial, etc etc but these are nothing too complicated to sort out.
    Here are some pics that have been floating about for a while, be adding some more as time permits.
      The Garlock chip/EPROM will do wonders, real improvements to be felt there, especially off the line!
      Will follow this thread
        This is where is most needs help!
        The car using about 10/lt/100km so I am considering the lambda probe will assist if it has not been replaced recently.
        (I shouldn't be so passionate about someone else's car, but as I am getting free reign in modding it, I have invested ownership! )
          Will be interested to see how you go with the chip, it's something I'm considering for my toledo
            All the cool kids have Cupra's.
            Have you thought about a lighten fly wheels.
            Quick bit of read says a lighten flywheel is the best bang for buck mod after intake and zorst.
              Interesting I agree on lightened fly but still will persevere for now without. I can't believe we bought this as a donor car!
              Tonight the ISV was cleaned with upper cylinder treatment and the dizzy cap and rotor got a going over. There must be a leaky seal on the dizzy drive as there was a good splash of oil on there!
              Short story, it idles better and pulls stronger in lower rev range now. Just need to sort out the rest of the business...
                just noticed that you're in the blue mountains? we should get our 2 cupras together..
                Phil
                Red 99 Seat Ibiza Cupra Sport, coilovers, K&N (Gone but not forgotten)
                2012 BMW X3 MSport 2.0D
                  For sure. There are semi regular get together in the lower mountains - PM me your mobile and I will get in touch.
                    Did a bit of a road trip in the little one on the weekend. Highway speed no aircon 400km @ 7.2lt/100km! Before tuning it was only getting 9-10lt/100 on those sorts of miles/speeds.
                      Needs moar awd and boost.
                      Hai Mick...
                        Hai Mick...
                        Haha, Pete you so funny! How was Marulan? Thanks also for the top hose.
                          What do you mean by tuning it? Did you get the ecu chipped?
                            Garlock EPROM is on order but for now it has had;
                            - New pod filter
                            - New oil/filter
                            - Remove/clean/refit Idle Stabilising Valve (was filthy) with upper cylinder cleaner
                            - Clean vacuum runner in the manifold with upper cylinder cleaner
                            - Replace perished vacuum lines
                            - Clean throttle body
                            - Adjust accelerator cable tension
                            - Remove/clean/refit distributor cap
                            So when the EPROM comes we will also replace the lambda probe.
                            Looking for more low end power (did a TLGP with Liam's GTI on the weekend and it was almost neck and neck!! I expected it to be a bit faster)
                              Subtle lows and decent shocks about to appear!
