Hello team.
I've posted several years ago about my jetta.
I know there are those who lurk forums from time to time and reread old posts about guys who have had projects and gotten somewhere but never posted an update..
I want to make sure that if there is even 1 person who is following this, that they have a comprehensive guide on tuning a twincharged Jetta the way I have..
I bought the car brand new from Barloworld VW for 19k (run out sale for 2014 models).
I originally wanted a grey, comfortline manual until the dealer stopped me in my tracks by telling me there is no manual option except for the base model..
Most people might overlook this preference and buy the upspecced model in spite of their original buying criteria.
I'm no ordinary buyer though.
I ended up with a candy white 2014 prefacelift (prefer the look) twincharged CTHD.
Now it's been 95K kms since I bought my car and have done several mods and lots of research over the years.
I understand that a 1.4L is a tiny engine and no-one should expect it to be a powerful adversary to say, a 2.0T.
However the S/C and T/C nature of this engine makes it an excellent performer who has more character than an outright more powerful engine.
So get to the meat of this post.
I have followed examples posted by several forums for various models who have the CAVD/CTH series engines.
Mods so far:
BC RACING BR type coilovers (7K Front springs) (6K rear)
Whiteline 24mm RSB with heavy duty adjustable endlinks.
NGK BKR7E spark plugs (copper version = more efficient and cheaper)
NGK U5002 coilpacks - have read that these will supply plenty of spark even for 1000hp RB26 builds.. for they will do for a 1.4
RTMG turbo inlet pipe
Custom air intake pod filter(3" to 2.75" silicone elbow to match oem supercharger hard pipe)
Stage 1 tune, boost set at 18psi - 130kw at wheels (dyno tested) (this was done whilst needing an oil change and pre several mods I've done since, probably up by a few KW since then)
2.5" catback exhaust pipe (kept stock resonator and muffler)
GFB DV+
And that rounds up the car so far.
It uses between 6.5-7.8L /100km depending on traffic and driving style.
The car handles miles better with coilovers but it can be slightly bumpy with the spring rate I'm running (wouldn't change it though)
I ran BKR8EIX plugs but they gave me misfires, even turning on soft limp mode once and the EPC light.
I now run BKR7E's until I need the 8s later on ... more on that later..
I have acquired the following parts in plans of chasing 300hp (and maybe further)
Awaiting install:
Wossner forged pistons
ZRP H Beam forged connecting rods with ARP2000 rod bolts
S3/MK6R oem intercooler
Hybrid OEM turbo from EuroCarUpgrades (rated at 300hp)
2.5" decat stainless downpipe
K03 oil restrictor (decat can lead to leaky turbo seals unless oil restrictor is used)
Wish list (perhaps one day)
Cat cams sport cam for the twincharger 260 duration
RTMG 420hp rated injectors (to avoid using WMI)
RTMG 380RS hybrid turbo
Golf R valve springs
Supersprint resonated exhaust system (for CTH Jetta)
That pretty much rounds it up.
I've collected knowledge and parts towards building an awesome daily, and I really mean that because I don't want to go too far with the build where I'll have issues.
The idea is to rebuild the engine using the 76.5mm pistons and not require a rebore.
New cam chain, tensioner and water pump to be done all at once.
Some tuners have been nervous about tuning the 1.4 with stock internals so I've decided to forge the bottom end for reliability.
The power increases are purely for overtaking flexibility and the mountain runs.
The upgrades internals will insure the engine can keep this up for years to come.
A lot of people may think I'm silly for spending all this time, effort and money into this little engine.
To me, it makes perfect sense because the jetta ticks my boxes for a family car which I will need soon.. so why not make it an awesome one?
Im not planning on buying another ICE car ever.. I'm simply going to wait it out until electrics are well established and readily available.
Until then..
I'll continue to make an awesome 1.4L with a fat torque curve and a good top end... as a personal farewell to internal combustion engines.
I always liked the Lancia Delta S4.. and since I probably can't own one- I'll make one of my own.
I'll continue to update this as the build gets underway.
Mods so far:
GFB DV+
Awaiting install:
Until then..
