03 Bora v6 4-motion clutch/gearbox issue
  • 03 Bora v6 4-motion clutch/gearbox issue
    I am new for this forum.
    I was really trying to find out issue for my car but I could not find any exact name of problem.
    Okay I am going to tell you my story.
    I bought a 03 Bora V6 4-motion on April from used car dealership. After I bought the car I went back home directly then parked about 5-6hours on street. I started engine then tried to shift gear but I could not move gear knob to any gears. When engine is off gear knob moves so I shift gear to first gear then start engine. Even I fully pushed clutch pedal to bottom it is half-clutch.
    So I sent to dealership 5 times for this same happening they said they changed New OEM clutch complete kit(includes slave cylinder and thrush bearing), new clutch master cylinder, and pressure hydraulic clutch hose. but still have same problem..
    Now I found how to make it work
    After bleeding gear works and moves fine but after few hours parking same happening again e.g. I drove to home then next morning gear does not move
    How I make to gear move
    1. turn on engine
    2. pumping clutch pedal for 10-15min
    3. turn off engine for 10-20min
    4. try 1-3steps for 3times more then gear works.
    Problem
    - Gear does not shift to any gear (Gear knop does not move)
    - Also when gear does not move I feel clutch pedal is low.
    - Before start engine I push in 1st gear, clutch engage point is really low. Even I push clutch pedal to end I can feel it is almost engage point.
    - After bleeding or pumping clutch pedal short distance(less than 10km) driving does not make same problem but long distance(at least 20km) driving makes same happening
    I am wondering what could be a problem, how much does it cost to fix or re-installation of clutch, any good mechanic around lidcombe, NSW?, and which is better to bring my car to general mechanic shop or clutch-brake mechanic shop?
    Please give me advises.
    Also this car has warranty from warranty national company
    Thank you
    Joe
    Usually sounds like a slave cylinder.... Take it to a clutch shop mate, or VW.
