B116229 Selector lever park position lock switch - Implausible signal Error
  • NSW B116229 Selector lever park position lock switch - Implausible signal Error
    Hi All,
    My VW Golf MY16 Comfortline Mk7 is showing the below error.
    Has anyone else had this error and fixed it.
    The car in not under warranty and would like to know how serious is this and the cost for fixing this.
    Would really appreciate if you could assist.
    NineVW
    I think that's a pretty common fault. In most cases it seems pretty transient. It's an issue with the selector mechanism I believe.
    Clear the fault and if it doesn't cause any issues with the selector not detecting the lock position correctly then just continue on.
    If it keeps returning or stops the car from being able to be moved off then you might have to look at replacing the selector assembly.
