I have had my Polo for about a month it is not registered yet. I have just fixed my DPF issues and it has gearbox faults which I will paste in below. It has sat in a shed for over 3 years after the previous owner got sick of the problems with it and trying to deal with VW.
I was told by the previous owner it had the mechatronics unit replaced and around a thousand k's later it started to intermittently fault and not select 1st gear. Not long after that it went into limp home mode because of being driven for to long with a faulty exhaust temp sensor and a faulty DPF pressure sensor. That's when they parked it. It is a 2010 diesel 7 speed comfortline.
Does anyone have any knowledge of the fault codes below?
2 Faults Found:
001836 - Gear 1
P072C - 008 - Not Selectable - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 40
Mileage: 193049 km
Time Indication: 0
Date: 2017.06.13
Time: 00:14:51
001852 - Gear 7
P073C - 000 - Not Selectable - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 193051 km
Time Indication: 0
Date: 2017.06.18
Time: 20:07:14
2 Faults Found:
001836 - Gear 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 40
Mileage: 193049 km
Time Indication: 0
Date: 2017.06.13
Time: 00:14:51
001852 - Gear 7
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 193051 km
Time Indication: 0
Date: 2017.06.18
Time: 20:07:14
