Glossary of Unfamiliar Terminology
This is a sticky topic.
  • Glossary of Unfamiliar Terminology
    Just thought I'd start a thread where terminology some of us (I'm sure I'm not the only one who reads these forums and comes across terms that they are unfamiliar with) are explained.
    I think, for the sake of those who might genuinely need help in this area, it is best if this is kept strictly as a "Glossary of terms explained" rather than a chance to sling the sh*t at someone who asks a question.
    I'll start the ball rolling by exposing my ignorance:
    "Swallowtail" as in MkI Swallowtail. I'm sure it's something to do with body shape, but for the life of me ... I cannot see the diff between a MKI described as a "Swallowtail" and one that is not.
    Dave
    good point Dave, i dont see any difference myself, also VAG im guessing means Volkswagen auto group or something?
      Great idea Dave. Ive stickied it so please keep this on topic other wise itll be edited mercilessly as alot of people would like to know these things even if it is easy for some. Heres a few i have learnt recently and some i have also known for a while. Feel free to contribute
      RSB = Rear Sway Bar
      CAI = Cold Air Induction
      LSD = Limited Slip Differential
      DV = Diverter Valve (this is a new one to me a i was from a Japanese car background)
      BOV = Blow Off Valve
      TIP = Throttle Intake Pipe.
      For Sale 2006 VW Polo GTI
      Have a Look
      CUSTOM CODE
      Phase 2
        Swallowtail
        With regards to the "Swallowtail", this was posted by Golf Loon and explains the difference between the Swallowtail and the later Mk1 Golfs...
        Originally posted by Golf Loon
        Check out this thread http://www.vwwatercooled.org.au/newf...ht=swallowtail
        You are looking at the back panel under the numberplate. On the 1975 built cars and early 76 it curves up at the ends like a swallows tail to meet the lights. On the later cars it is a straight line.
        The cars also have several other cosmetic differences, bonnet without a line across the front, no cutout for fuel sender under rear seat, different fuel tank and unique clips up in the headlining by the tailgate.
        They are pretty rare everywhere and are worth good bucks overseas.
        Canadian dubs coming to VWwA soon
          VAG : Volkswagen Audi Group (now includes SEAT and Skoda). They also own a few others like Bugatti.
            Wrong wrong
            VWAG or VAG stands for Volkswagen Aktiengesellschaft
            Aktiengesellschaft is the Germany equivalent of stock trading company http://en.wikipedia.org/wiki/Aktiengesellschaft
            The origins of the Volkswagen Audi Group name comes from a time when VW & Audi UK worked together V.A.G UK
            - Ben
            2008 Jetta 2.0L FSI
              Some things I find often catch people out are different names for the same item. Depending on where you got your car info from to begin with - you may be familiar with one, and not the other.
              A damper is the same as a shock absorber.
              A swaybar is the same as an Anti-Roll Bar. A third, less commonly used name is a Stabiliser Bar.
              A Propeller Shaft (or "Propshaft") is the same as a Driveshaft.
              "HID" is often treated as synonymous as "Xenon", but this is technically a fallacy. HID refers to "High Intensity Discharge" lamps - a generic term that covers more than one type of light. The "Xenon" HIDs seen in cars are Metal Halide lamps - it would theoretically be possible to substitute the Xenon gas for another inert gas like Argon, but the warm-up time would be considerably longer. These are distinguished from "regular" incandescent lights by the lack of a filament - HIDs generate light by heating a gas/metal mixture by means of an electrical arc.
                My Definition...
                A Driveshaft is found on front & rear wheel drive cars carrying the drive from the front or rear or both diffs to the wheels. A 'prop' shaft generally runs from the front of the vehicle to the rear under the centre of the vehicle e.g. convensional gearbox to the rear diff. So all Synchros,or '4 motion's have 4 drive shafts & one prop shaft. ........ Bazz Is this correct?
                  Originally posted by shaneth View Post
                  RSB = Rear Sway Bar
                  Also commonly abbreviated as ARB = Anti-Roll Bar.
                  FF = Front-engined Front-wheel drive
                  FR = Front-engined Rear-wheel drive
                  MR = Mid-engined Rear-wheel drive
                  RR = Rear-engined Rear-wheel drive
                  4WD = 4-Wheel Drive (permanent rear-wheel drive with a function to drive the front wheels as well)
                  AWD = All-Wheel Drive (permanent drive on all four wheels)
                  HP = Horsepower
                  kW = kilowatts
                  Nm = Newton metres
                  Present: Mk3 Golf variant.
                    American usage of the word 'Driveshaft' covers both the longitudinal shaft (front to back) which is known as a 'Propeller Shaft' by the British, as well as the transverse ones spanning from the differential to the driven wheels.
                    The transverse shafts connecting the differential to the driven wheels are generally called a 'Halfshaft' by the British (and thus all British publications). You'll sometimes hear the F1 ITV commentators referring to "Halfshaft Failure".
                    I guess I wasn't clear enough in my earlier post - sorry for the confusion.
                      And GTI is Grand Touring Injection. I have read that it was VW who coined the term, is that right?
                      very interesting thread
                      de
                        Conversions:
                        Power:
                        Power (kW) = Power (HP) x 0.7457
                        Power (HP) = Power (kW) x 1.341
                        Torque:
                        Torque (Foot Pound) = Torque (Newton Meter) x 1.356
                        Torque (Newton Meter) = Torque (Foot Pound) x 0.7374
                        SMIC = Side Mount Itercooler
                        FMIC = Front Mount Itercooler
                        TMIC = Top Mount intercooler
                          Interesting and essential thread.. good work.
                          I learnt a new word.
                          "suitcase" = mid muffler.
                            Bumpety bump. Instead of just posting up with items like this ... USE THE DAMNED SEARCH FUNCTION!
                            Dave
                              Bump
                              Thought it might be time to resurrect this ol' thing and demonstrate a bit more of my ignorance ... in other words, ask for some help with terminology definitions ... such as:
                              1. 'Shave' (as in 'a shaved panel').
                              My guess is that unwanted (or considered unnecessary) items are removed from a panel, holes are filled & sanded and a respray makes the whole thing look very smooth and uncluttered.
                              Any additions / alterations to that summation welcome.
                              Um ... I'm sure I'm far more ignorant than just that one item ... I'll have to add stuff as it occurs to me.
                              Dave
