Have any of you seen this "new concept" engine? Home | EcoMotors
Old Bill Gates has just thrown a fist full of money at it. The opposed pistons idea is pretty novel.
The revolutionary opoc architecture of opposed pistons and opposed cylinders provides unparalleled benefits
Opposed-Piston Opposed-Cylinder Engine
This patented design creates a ground-breaking internal combustion engine family that will run on a number of different fuels, including gasoline, diesel and ethanol. The engine operates on the 2-cycle principle, generating one power stroke per crank revolution per cylinder. It comprises two opposing cylinders per module, with a crankshaft between them, and each cylinder has two pistons moving in opposite directions. This innovative design configuration eliminates the cylinder-head and valve-train components of conventional engines, offering an efficient, compact and simple core engine structure. The result is an engine family that is lighter, more efficient and economical, with lower exhaust emissions compared with conventional designs. Here you can see this revolutionary 2-stroke engine in operation, which helps to illustrate the simplicity, elegance and compactness of its design.
HAHAHA
