What battery should i get???
  • What battery should i get???
    Hey guys i need a new battery mine is kaaa---puttttt!!!!
    A replacment battery is $170 :O thats for a supercharge gold. (last one lasted less than 9 months )
    what should i get??? i want to run a good sound system and just want it to start every time no hassles!!
    Stu
    Surely that'd be within the warranty period?
    I'm a fan of the Optima range, but they're expensive. That said, an Optima Red Top would be good if your car will be sitting still for a long period of time...
    Otherwise, Century seem to have a good reputation.
    Nothing to see here...
      Yeh it is under warranty... BUT...i have a ruined rep with my old boss who it was purchased from and he will not replace it.
      What do you use??
        Longest lasting one i had was a Varta, they also make OE Batterys for VW i believe...
          I can get a heavy duty century for 113 that good???
            What do you use??
            The warranty for Supercharge Gold is 3 years. Your old boss may not want to replace it but any outlet that sells it will regardless of where it was purchased.
            The Supercharge Gold MF66 has a 670CCA with RRP of $219, the Century DIN65LMF only has 580 CCA and 2 year warranty but RRP is only $179.
            Granite Passat sedan TDI (125kw), DSG, beige leather
            Candy White Polo 6R, 66TDI, DSG, no options
              But I can't get a receipt...
                stu get an optima battery you cant go wrong man, pay the extra $$ for the real good shizzzzz
                85' MkII 1.8 K-jet(small Bumpers) SLAMMEDDD!! ( sold )
                91' MkII GTI sold!
                  you shouldn't need a receipt. When you fitted the battery, you should have marked the purchase record on the battery. That should be good enough for any bonafide dealer. If it's a 3 year warranty then it's probably 6 months FOC replacement then pro-rata after that. I'd recomend you contact Supercharge direct & ask them what your options are.
                    as if the battery is actually dead? It's not that old, it should be OK, unless it's been damaged.
                    Both my cars have crappy (brand) and old (ones dated '06) and they both work still.
                    Even my battery in the diesel went flat (completely!) a couple times, but it was still good!
                      Optima D34 Yellow top. $300. Call me baby.
                      Other than that it doesnt realy matter too much. If you think you are going to have a problem with constantly discharging the battery then get a deep cycle. If you want it to last a long time without the car running then get one that has lots of Ah (amp hours) CCA only has to do with starting the car realy. Look for around 40-50ah. Keep in mind the more Ah the battery has the bigger it will be.
                      The D34 is rated at 55ah and 750cca. It also has a LIFE TIME REPLACEMENT WARRENTY. $300 is really cheap and really worth it.
                      MK1 GLS 3door
                      A4 B7 2.0T
                        I have a Century Optima.
                        Go see these blokes: Battery World | Store profile
                          I can't afford 300 :O
                          I'll see what the bet deal I can get is
                            Got it replaced under warranty!
