I reckon an hour or so is debateable... I've done mine before and it took me about 3, on and off. I took about 30 minutes to clean up the surfaces properly and unfortunately I had to manually undo and redo the bolts. Changing the gasket was the easy part hahah....
Fair deal? $300 to fix oil leak?
VW!=Toyota when it comes to mechanical philosophy/designOriginally posted by DubSteve View PostTook me about 1 hour to do the mk1 when I had it, and that was sump gasket and all.
When i had the Mk3.5 Cabrio I was suprised at how many things were relatively easy to fix compared to other cars.
toyotas are 1) easy to service. 2) Generally reliable. 3) Often a bit of a pain to do repair work to unless you have some of the Special Service Tools.
Maybe the guy at K-Mart just doesn't want to do the job & has quoted high to put her off. I had a roof cleaner do that to me last week $2200k to water blast the lichen off my roof & spray the tiles with bleach afterwards.carandimage The place where Off-Topic is On-Topic
Take it in to somewhere they know what they're doing! There should be a decent specialist around your area and get a quote from a dealer as well.Originally posted by hoontime2 View PostNOw my mum took it in the second time to get a proper description of the problem, they said it was leaking and 8,9 hours work. $1400.
the top gasket and bottom needs sealing and on the corner there's a hole.website: www.my-gti.com
get another couple of quotes. I think you'll find the KMart guys don't want the job.
Surely some of the BNE folk can recomend an honest & fair charging repairer near the OPs area.carandimage The place where Off-Topic is On-Topic
This has me puzzled.
Why not ask a Holden dealer for an estimate first. (Estimate, not a quote)
Now I don't know if Apollo did or did not come from Toyota. But check there for a second opinion.
My Toyota dealer (Country town) service charges always less than similar charges in Sydney.
BTW, When my 118TSI arrives, will be serviced at local Holden dealer. (VW, Holden, Mitsubishi, Nissan. hope these guys can
talk VW properly!)MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
