So i sussed a t4 with seats today and the end of the seat belt was indeed bolted to the mounting point below the retractor. Perhaps the seat belt i got with the seat come out of a swb or indeed just a front one where the pillar is lot closer. Either way i'm confident i can make it work. Mechanic cautioned against attaching to the seat aswell reckoned through the floor was better but to check with engineer.
Fitting rear seat in a T4 licensing stuff.
If the seat is an original VW one then it would be set up for a Caravelle probably also the height of the pillar mount does have allowances which van be as much as 150 mm either way from a central point . There is a special template we used to use and it gave an arc behind the shoulder to work from , we used to buy new belts for any second hand installation and there were some longer ones around , mechanic is right use the floor .
