Hopefully somebody can help. I recently bought a 2002 T4 Transporter 2.5 diesel. Today I noticed what I thought was brake fluid leaks under it. I was getting tyres put on and it was on a hoist to be aligned and the spots were on the ground as l drove in. When I went to drive away the clutch pedal was on the floor fully in. I pulled it back up and I drove it around to a mechanic who had a quick check and said it was clutch fluid and it appears it's the master cylinder. It was late so I'll drop it up tomorrow morning to get it checked. The problem I have though is the bloke I got it from gave me a receipt from a mechanic saying a new clutch master cylinder had been fitted in November 2015 at 225,000 k's. It's now just touched 228,000. Surely they would last longer then that? Also is this an expensive fix and difficult? Any ideas would be very much appreciated.
Clutch leaking fluid
Might be just a poor connection when he changed it.
By memory, the brakes and clutch shared the same reservoir so it's best to keep it topped up!
I changed one once.........petrol motor though but I wouldn't think they'd be too different...........2003 model.
The part wasn't too expensive but the pedal cluster is a pain in the arse!2018 Crafter Runner
2012 T5.1 6sp manual.
2024 Crafter Auto
Also check the actual pedal mount there was an issue with the mounting being weak and it will crack around the base , on my sons one it was like this and because it went out of alignment it caused the master cylinder to leak BUT I think it leaked internally onto the floor so might not be your problem but still worth checking .
Thanks fellas. I'm completely new to vw and I hope I don't regret getting it. The mechanic said he just hopes it's not inside the gear box. Although as I understand it that's the slave cylinder. What would be a reasonable price to have a new master cylinder installed do you think?
I can't recall how much the part was but I think it took about two hours.
VW stuff is weird..........some parts are expensive while others are cheap.
I'm yet to find out why.
Like Sunny says, the bracket that holds all the pedals is of poor design.
I went through three in nearly 600,000 kms.
The bracket is an expensive part.........more than the master cylinder by memory.2018 Crafter Runner
2024 Crafter Auto
Yeah......cheap enough.........backorder with them though.
701-721-401/B / 701721401B - Clutch Master Cylinder T4 TDi 1996–2003 - 1130601500, 701721401B, 110306546, 34832, - :: Just Kampers Australia
Probably plenty on ebay.2018 Crafter Runner
2024 Crafter Auto
I have been quoted $1,000 - $1,200 as it's the slave cylinder. Labor is the killer. I do get 12 months warranty with it where I wouldn't if it came from Just Kampers. The clutch pedal has been previously welded. The mechanic who just done my major service told me everything else is good. I suppose nobody can ever predict failures on a used vehicle. As well as being my first VW it's also my first diesel. It's just being on a pension it's difficult with limited funds. Hopefully I might be able to get to know somebody in the Newcastle area who has a Transporter as well and might be able to get together and help each other out.
Originally posted by Fossil View PostThe mechanic said he just hopes it's not inside the gear box.
How does the clutch feel?, any shudder? If you can afford it a new clutch kit & dual mass flywheel should be fitted while everything is apart.Understand how it works, troubleshoot logically BEFORE replacing parts.
Numerous Mk1 Golf diesels
Originally posted by Fossil View PostIt's just being on a pension it's difficult with limited funds. Hopefully I might be able to get to know somebody in the Newcastle area who has a Transporter as well and might be able to get together and help each other out.
I do hope you find someone local to you with mechanical ability.Last edited by jets; 20-07-2017, 12:37 PM.Understand how it works, troubleshoot logically BEFORE replacing parts.
It's already had a ew clutch kit put in only 3,000 k's ago. Flywheel etc already done. The clutch is nice on it and gears change without a problem. It's just a failed slave but falls out of the warranty period. I asked for a written quote and he came back at $1,300 and not $1,200. I think if a mechanic gives you a written quote they can't add more to it when it comes payment time. Is that correct?
Good result, glad it had a happy ending. Thanks for reposting.Understand how it works, troubleshoot logically BEFORE replacing parts.
Originally posted by Fossil View PostIt's already had a ew clutch kit put in only 3,000 k's ago. Flywheel etc already done. The clutch is nice on it and gears change without a problem. It's just a failed slave but falls out of the warranty period. I asked for a written quote and he came back at $1,300 and not $1,200. I think if a mechanic gives you a written quote they can't add more to it when it comes payment time. Is that correct?
As per the written quotes, I always write down that if it would be more than +/-20% I call you to approve it, in other word, the quote is always within 20%.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
