Hello all
Its been ages since I have been on here due to the fact my van has been running without any faults.
I took the family down from Perth to Margret River to see the the Margret River Pro surf comp and about half an hour from Margs the power steering went. I know the auxiliary belt (power steering, air con, alternator) had slips and pulled over after about 5 min of driving (looking for a suitable spot to stop. I usually had a spare belt and pulley tensioner in the van but just had the van, Just before we pulled over the van lost power and I was forced to pull over at the side of the road!!!!
I tried to start it again and it would not turn over. I waited for the Rac tow truck to bring us to the accommodation and deal with later.
I pulled the engine cover off and yes the pulley had shat itself and the belt was toast.
So two days later I managed to get new auxiliary belt and tensioner pulley and fitted, Now the van wont start.
It turns over ok, I jumped it to another car for testing purposed so battery was good.
So far I have tested:
Fuel pump - tested and could see it pump fuel (new pump about 3 weeks ago)
Coil Pack and distributor cap - tested for spark on centre cable from coil to cap and have good spark, inspected cap and seems good.
Spark plugs seemed to be good condition and plug were wet.
I tried spraying starter fluid down the carbie and nothing it just wont start. as mentioned it turns over Ok but wont run.
My fear is the van is stuffed, possible issue with the timing belt slipping when the aux belt slipped, could be a timing issue.
Any other areas you would recommend me testing?
Its my work van so sort of stuffed without it, Love my T4 dont want to see her go down like this!!!
T4 2.5ltr petrol 1998
