I'm looking at ways to recess a fringe into the chassis, and i noticed that Reimo do a water tank that requires the rib to be cut out on the driver side behind the seat.
Has anyone done this (cutting the rib out), it looks like a great way to increase space, by enabling the cupboards to be shallower than needed.
Surely it can't be structural, if Reimo do a water tank for that area once the rib is removed...
As the tank is 74mm at its widest, so in theory i could reduce the cupboards by 40mm-50mm to give myself more space for turning a wheelchair, once i install the cabinets.
Can we remove a lower rib here in Australia???
we take them out of the window space when we install the bonded glass, and the drivers side is designed for a sliding door......
