12V switched/IGN under drivers seat
  • 12V switched/IGN under drivers seat
    Hi,
    Does anyone know if there is a IGN point under the drivers seat that can be tapped into?
    Under the drivers seat I have installed a redarc BCDC1225 (DC TO DC CHARGER) and would like to also connect solar panels to the system which requires a changeover solenoid to be installed that is triggered by the IGN.
    There is, just not sure which pin-out.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Test meter would probably give you an answer don't use a test light as it may cause a short .
        This is from 2005 4Motion, under the front passenger bench seat. Still I recommend that you use the digital voltmeter to verify the +12V with the ignition on.
        Performance Tunes from $850
        Wrecking RS OCTAVIA 2 Link
