1995 T4 petrol 2 ltr. does the tacho run off coil or alternator ?. The issue I have is that the tacho has become very 'jerky' in its movement and when i turn ignition off it stays on 1000 rpm. (the dial not the motor) if i then just flick ignition on and off again the dial goes to zero !! any thoughts ?
Does tacho run off coil or alternator ?
Powered by the electronic ignition.
That would more than likely be a sticky instrument movement at a guess.
Just to add - if it sticks again when turned off, give it a tap on the glass or around the instruments to see if it moves back to O.
OK thanks for that, will try next time
