[QUOTE=YellowLemon;1134437]2011 MY bluetooth works fine with iPhone.
1. Have you tested with another phone and it's all working OK? So the problem is JUST iPhone?
2. What do you mean 'not recognising'? Ie, you go through the MFD menu, do "Add new phone", and it can't see your phone? Have you put your phone into pairing mode first.
2. Just after you turn on the car ignition, on your phone do a bluetooth scan can you see "VW" in the bluetooth list? Just add that (from the phone) and it should work fine.
Cheers for the quick response
I have tried all of the above except for a different brand phone!! If this doesn't work my Bluetooth must be broken, I have paired my phone with a lot of different Bluetooth systems and got it to work fine, on the MFD in the van it said looking for phone but it's not finding my iPhone!!
I might have to pull the radio out and see what is going on!
And I will give the installation of the RVC a go in the next couple of weeks
Thanks again
Thanks again
