I have the head off the 2.5 syncro petrol T4 following the loss of the rad cap, coolant and then head gasket!
The thing I need to consider is that the front/rear crank seals are leaking and this seems like a good time to change them. Then If I'm doing this then the clutch as well and then the rings too ... So can I get the block out and leave the gearbox in place?
