My '05 Multivan started puffing into the airbox ( 170,000km). One inlet valve stuck open, and one lobe worn completely off camshaft.
Sourced 2nd hand engine (130,000km)from Sydney, lifted the rocker cover and found the same problem.
Always used the VW spec ( dear) oil, at recommended interval.
Change your oil more often than recommended 15,000km interval, and I suggest using some sort of engine flush to clean the deposits out of the oil galleries to maintain oil flow to all the clattering internals.
Keep an eye on water pump leakage( into the block!) which quickly gums up the oil and exacerbates the problem.
