The Valeo cooling fan on the right side of the engine bay (the one for the air con & heater that always comes on when you flick the fan switch inside) is approaching its expiry date with an almost constant squeal when the cabin fan is on.
I think the part number is 7D1959455J but I'm not certain given that there are two possibilities. VW Heritage has this part for around $100.
While replacing it with a VW part is laudable...I suspect it'd also be laughably expensive. So I'm far more tempted to get a Davies Craig fan or similar from the local Bursons. Or even the VW Heritage unit
Anyone got any leads on what might fit as a replacement fan or am I better off going with the VW part?
