By chance does any one know the wiring color codes for the drivers door on a 2005 T5 .The drivers side locking solenoid has stopped working but it seems it is probably a fractured wire going through the grommet as it will lock all the time by remote and then occasionally it will unlock for a few times by remote . It's a bit of a pain using the key to unlock , thanks in advance guys .
Drivers door wiring diagram T5
Can't help with the wiring diagram, however I head exactly the same issue but in the passengers door and researching the UK T4 forum mentioned that before pulling the front door panel apart etc. check the wiring under front passenger seat for corrosion etc. as that is a common cause if the issue-yet to get around to doing mine (pass. door so not as pressing).
Matt
My passenger door repair here
How to remove Door Lock and Assembly Carrier - The Brick-yard
I didn't take notice of the wires, but the connector going to the actuator here, may help
Steve
04 T5
