Hoping someone can help with wiring a genuine VW camera to a new multi. I need to connect the ground, Reverse +ve and 12V +ve somewhere. I was thinking of the following connections:
Gounding to the bolts in the tail gate
Joining the power and reverse power cables together and connecting to the reverse light wire.
I have taken the tail light assembly out and there are 5 wires in a connector with 1,2,3,4,5,6 pins. I have tried putting the van in reverse and using a multimeter to identify the reverse wire however they all show 12v which doesn't seem right. When I take it out of reverse none show 12V. Can someone assist with identifying these pins or offering an alternative location to wire back to?
I have also tried to test the camera after connecting to the RNS510 and nothing shows. Does it need coding before it will display the image?
cheers,
cheers,
