2005 Multivan Electrical problem?
    Originally posted by Sunny43.5 View Post
    .Okay a little more on this one as I now have a new T5.2 should I be looking to buy a VAG COM as it seems that its almost mandantory to own one to find out what has had a hiccup !!!!!! and to keep it going without resorting to VW roadside assist I don,t look forward to a new van that has some of these little idiosyncrasies when ever it decides to . It just should not happen .
    Howard will you just go and enjoy your new van!
    Stop worrying!!!
    M
      Pulling fuse 3 (multifunction control module 1) on the top box in the console fixed it, ill plug the vcds in later to see if there were any codes
      2006 T5 4motion 128kw Multivan
      1960 Karmann Ghia Coupe
      Yamaha TW200 Salt Flat Racer
        Mfc unit guide from vw
        (edit, bloody useless document)
          Originally posted by jimby View Post
          http://www.vwn-aufbaurichtlinien.de/...T5_2012-05.pdf
          No, that's a good document and useful.
            Okay Cousin I agree after the auto episode and the other stuff I suppose it will take me some time to get over my paranormia . I think I should stop visiting the forum as I just read everyones problems and think HMMMM will I have that one ???? But your right I am already enjoying the new one have ordered a suspension kit and factory cruise from Tidy Transporters in England this is the kit T5 FK Highsport Coilovers -100mm and this cruise T5 Cruise Control Kit Some good over Christmas work to do plus the full fit out inside windows also coming locally .
              Agreed. Didn't know there was an english version of it.
              I carry a hard copy of the Amarok one in the van with me, for those who want additional electrickery.
                On starting the engine after a quick stop today, I noticed the dash lights, indicators, A/C fan and window operation were not working. Stereo was still working surprisingly. After I got home, once the engine had cooled, I started the van again and everything was working fine. This problem has happened before, however after turning the engine off for maybe a minute, everything worked again last time.
                I should add that the A/C does not work. It was also reasonably hot today.
                Can anyone shed any light on what the problem might be please?
                05 T5 Multivan 2.5 TDI
                  It needs a scan otherwise you're just guessing. Assuming that you had a recall fro the el. wiring done on it.
                    Thanks for the reply Transporter. We had the recall 97W8 which was for the harness for the cooling fan. Apart from that, I have no knowledge of the recall you are talking about. Do you have any more info on it please?
                      This fault has been mentioned on the forum many times before, and is thought to be a logic fault in the controller firmware that VW has never fixed. Take a look at this thread for example, look for my 3rd post under brianj down the first page.
                      Here is the main text:
                      "I turned off the ignition, removed the keys, then opened the drivers door and then manually locked the doors then unlocked them, then closed the drivers door. I then put the keys back in and turned on the ignition, and the aircon light was now working."
                      Brian
                        Thanks for the info Brian. This time, turning the ignition off and locking and unlocking the doors didn't right the problem unlike the first time it happened. Looks like it's off for a scan...
                        • #27
                          Try reseating and checking the fuses under the battery in the motor compartment, I mentioned this earlier in that same thread.
                          Let us know what they find.
                          Brian
                          • #28
                            Update...today after turning the ignition off and removing the key, the heater and lights we all still on??!! Will be taking it for a scan in the next week or two.
