I am having trouble with water leaking inside the drivers side. I had the windscreen replaced about a month ago but there has been no rain until last Friday, then I found quite a lot of water on the floor.
When I first got the T4 it did the same and I assumed it was coming in the 3cm holes in the tray under the windscreen so I plugged them up, it stopped leaking in but also created a pool of water in the tray that had to evaporate which is not good.
So I guess it must be the windscreen leaking but I have read on the UK forum that the water can also come in through the "A" pillar and cause the same problem.
- Should the two 3cm holes be plugged up ? and did they have pipes to drain water away?
- if they should be open, where does the water drain to ?
Thank you.
Thank you.
