VW keeping me poor
  • VW keeping me poor
    Well, I had a service today, and I suspected a leaking exhaust manifold... yep... $1850 fitted. Then they stripped the sump (at the plug) another $995, came away over $3000 lighter. all this under 150k.
    Makes my Falcon look good.
    No Cheers
    Col
    Does the sump plug get replaced at every service?
    If not, I'd be finding out who didn't replace it last, and forwarding the $995 bill to them.
    The manifold job sounds dearer than the last one I did back in the dealership days, by a fair margin.
      No Cheers
      Col
      Why didn't they put in a helicoil?
        Sounds a bit like you didn't get quotes from several shops for the leaking exhaust.
        If the repair shop stripped your sump, I would not pay for anything more than a helicoil insertion.
          Even if they replaced the sump, there's not almost $1000 in it.
            Hi Guys.
            I did a day ringing around on the manifold. From VW they are quoting around $1000 plus gaskets ( 3 sources). I tried the sump on them, they were the last and second last people to work on it. Helicoils dont work, as they leak along the thread (Yep, I would have thought that's what the washer is for).. Can you tell I'm pissed.
            Col
              So was a dealer the last who worked on the van ? then they MUST bear the responsibility for stripping the plug sounds like time for some jumping up and down holding your breath until turning blue with legs and arms flaying . No swearing it never works .
                Because it is cr*p. I hate when I undo the sump plug and helicoil thread comes out on it.
                  Hi Guys.
                  Col
                  I wouldn't certainly pay for them to fix their cross threaded sump plug. It's their stuff up and they must deal with it, it's simple like that.
