Is anyone familiar with this problem?
My 1994 T5 Transporter often stalls as I come to a halt at intersections etc. It seems to happen more when the engine is hot. Going down through the gears to keep the revs up seems to help but not always. Work done so far to try to isolate the problem includes:- New spark plugs, Checked for air leaks, throttle body cleaned, PCV removed and idle air mixture valve cleaned, rotor button and cap cleaned, basic idle setting carried out.
The engine stalls while the van is in gear and the clutch pedal depressed. No problem when changing up the gears, even if I deliberately coast with clutch disengaged.
I am wondering if anyone knows if this is a known problem with this model. I hope someone can help as I live in a country town without VW diagnostic equipment.
